Home > General > Is this a defect in rrsport bodywork? |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
here are some other shots I found online some have gaps others dont?
Thu Apr 17 2014 10:26pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Just checked mine - fine - but mine has been face lifted - the lights have to be perfectly aligned to allow the securing brackets to snap into place so i dont think you can fill the gap that way. The bonnet does give on both corners but it naturally pulls back.
Thu Apr 17 2014 10:45pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
I wouldn't worry about it too much, it could just be the headlight hasn't been alligned correctly after having a bulb changed.
Thu Apr 17 2014 10:46pm |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
Mine's OK, just checked. Hope you get it sorted as it looks like a nice car. |
Thu Apr 17 2014 10:56pm |
Thanks guys, appreciate that. you make me jealous with the newer models, but guess I have to start somewhere I'll go take a look at it before I give any cash over. The man is a genuinely nice guy and I don't think as a dealer he is trying anything, it just looks suspect. Perhaps I can fix it with adjusting the headlamp again, the other side off the jeep looks better than this side, so it might just be that.
Thu Apr 17 2014 10:57pm |
You know that we need an update tomorrow, right? |
Thu Apr 17 2014 11:01pm |
Can do mate
Thu Apr 17 2014 11:12pm |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
The power of the v8 lifts and shapes the bonnet |
Fri Apr 18 2014 12:22am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
JEEP??????????
Fri Apr 18 2014 4:56am |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
May be just a matter of adjusting the bonnet and locating it correctly or possibly realigning. The bonnet locates on catches above each of the headlamps
Fri Apr 18 2014 9:20am |
Its a feature.
Fri Apr 18 2014 10:27am |
Good lads, good advice. I've the guy taking it to a body shop to check it over, I'd guess they will sort it. But at least it is fixable, its been HPI clear so I've no worries over that. Just a cosmetic glitch.
Fri Apr 18 2014 11:15am |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 |
Less than an hour to go then ........................ |
Fri Apr 18 2014 12:04pm |
mike_D_3781 Member Since: 09 May 2013 Location: west Yorks Posts: 98 |
Looks like that bonnet is buckled, it's definitely been in some sort of strife, the panel gaps across the sport especially at the front are usually pretty uniform, if you look closely at the front grill it's super snug, and lifted along the entire edge on the near side, pretty badly tbh, so someone's bent it for whatever reason, it'll be an interesting job for a panel shop, as the paint won't like being pulled and stretched, as they heat that bonnet into shape you'll be wise to get them to clay that bonnet, get a sun torch and depth gauge and see if it's damaged the paint.
Fri Apr 18 2014 12:55pm |
