Home > Tips & Tricks > Memory Seat Does Not Move Fully |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
I think your dealer is correct, its 'easy entry' or the memory seats.
Tue Jan 07 2014 10:17am |
stealth Member Since: 09 Jul 2014 Location: Hampshire Posts: 30 |
Thats how i understand it do you use two keys ? |
Sat Sep 20 2014 12:03pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Yayyy! You reached the milestone stealth. What are you planning to sell? |
Sat Sep 20 2014 12:06pm |
96 TDV6 SE |
Sat Sep 20 2014 12:26pm |
Socketuser Member Since: 23 Oct 2018 Location: Preston Posts: 7 |
How can I turn off easy entry, to take advantage of using two key settings. |
Tue Sep 10 2019 8:49pm |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
on my2007 lazy entry is on, lazy meaning you don't have to press a button on seat but works as well, the lazy being the remote unlocking of car cause the seat to go to the position it was last in when that remote was used, works for each remote - in theory
Tue Sep 10 2019 9:31pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
If your car is a 2013 MY13 with keyless entry you can't because it doesn't actualy have it, the seat memory settings buttons are on the door panel, and the steering column auto adjust setting is a rotary knob on the left of the steering column, although you can use the key buttons to do a few things. Cheers Col |
Tue Sep 10 2019 11:29pm |
