Home > Tips & Tricks > Memory Seat Does Not Move Fully
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
My wife drives the RRS nromally and she has the seat quite differently from mine (a lot higher and a lot further forward). When I open the door and press my memory position the seat does not move fully to my position until the door is closed and the ignition turned on. This makes it very hard for me to get in.
The dealer tells me this is due to the easy entry being active and the only way to get the seat to move to the memory psotion is to turn the easy entry setting off.
This would seem a very silly situation as what is the point of having memory seats to first get into the car.
Any help please?
Post #408455 Tue Jan 07 2014 8:28am
I think your dealer is correct, its 'easy entry' or the memory seats.
It's something I like on my BMW, it remembers the seating for each driver (key holder) so if I unlock the car, it's set up for me (seating, radio stations, air con etc) and if Mrs Bean unlocks with her key it has her settings. Cool ON THE WAY: BMW F21 M140i
Post #408467 Tue Jan 07 2014 10:17am
stealth
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Thats how i understand it do you use two keys ?
Post #437162 Sat Sep 20 2014 12:03pm
fkarim
Yayyy! You reached the milestone stealth. What are you planning to sell?
Post #437163 Sat Sep 20 2014 12:06pm
stealth
96 TDV6 SE
Post #437165 Sat Sep 20 2014 12:26pm
Socketuser
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Baltic Blue
How can I turn off easy entry, to take advantage of using two key settings.
Post #586691 Tue Sep 10 2019 8:49pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
on my2007 lazy entry is on, lazy meaning you don't have to press a button on seat but works as well, the lazy being the remote unlocking of car cause the seat to go to the position it was last in when that remote was used, works for each remote - in theory Mr. Green
read the ignored owner manual Arrow
Post #586694 Tue Sep 10 2019 9:31pm
If your car is a 2013 MY13 with keyless entry you can't because it doesn't actualy have it, the seat memory settings buttons are on the door panel, and the steering column auto adjust setting is a rotary knob on the left of the steering column, although you can use the key buttons to do a few things.
Post #586699 Tue Sep 10 2019 11:29pm
