Home > Technical > 05 Range Rover Sport Tdv6 SE starts then stalls
monkers2003
No worries mate. Is yours fine in the Summer months?
Do you have the same symptoms as mine?
Post #406504 Tue Dec 17 2013 5:53pm
monkers2003
Post #406505 Tue Dec 17 2013 5:57pm
monkers2003
Just an update
I cleaned the maf sensor the other day with some electrical cleaner and so far so good.
Starts as normal with no stall after startup
Hopefully this has resolved the problem!
Post #406830 Fri Dec 20 2013 6:52pm
Claus1949
I have just done 2 clean ups of the injectors, 2 full tanks with the cleaner, and since I have no problems starting.
Post #407923 Fri Jan 03 2014 12:26pm
monkers2003
I am afraid to say that the problem has reoccurred. Was starting for ok for about 5 days now it's back to starting then immediately stalling after. Resulting in a hard start with lots of cranking.
Post #408170 Sun Jan 05 2014 11:14am
Gilly
United Kingdom 2005 Range Rover Sport TDV6 SE Siberian Silver
New to this please forgive me if I sound a little thick
Have same problem with tdv6 starting when cold, had to sit with a few extra revs while screen cleared before engine would tick over, been to dealer to read fault codes but no codes shown, didn't seem to have heard of this before, best suggest was to change the fuel filter as I've only had the car for a few months and don't know full history, as anyone manage to solve, would appreciate if you could post
Post #410856 Thu Jan 23 2014 9:34pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
hi mines doing the same did anybody find the cure thanks in advance
Post #428522 Thu Jun 26 2014 6:28pm
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Hi
Not sure if this helps but it might so I will tell the story..!
Fair few years ago I had some work done to the RRS tdv6 (some belts changed) and the next day what you describe was happening. It would start and stall then you would have to crank and crank for it to start which it did (mostly just before a dead battery!) it would run fine and if I switched it off for an hour or so it would start fine until I left it overnight then it would struggle to start again after it had fired up and died.
I'm no mechanic so will try to explain in laymans terms what it was.
The garage who did the work on the car previously found the issue to be a valve which is under the black plastic engine cover at the back in the middle (looks like a car tyre valve) was leaking (fuel I was told). This valve I think is used for measuring pressure by mechanics etc but mine had developed a leak so loosing pressure overnight making it hard to start.
He replaced the valve (I think he used a tyre valve) and all has been good. I still have the car and all is good and it's been a few years.
When the mechanic took the plastic engine cover off he / I could see it was damp in the area of that valve. May be worth a peep to see if you can see dampness around that valve area or on the bottom of the engine cover.
Hope it's a simple as mine was to fix..
UK Guy RRS HSE with a few extras & a
2013 RRS Autobiography
Post #428535 Thu Jun 26 2014 7:20pm
hard2beat2014
will check it out thank you
Post #428539 Thu Jun 26 2014 7:54pm
Gilly
Hi thanks for that, will check it out, did suspect air getting into fuel line but most garages spoke to think it was the low pressure pump on its way out but not sure
Post #429473 Sun Jul 06 2014 2:02pm
Gilly
Had a look round and vale doesn't appear to be leaking, über the last month or so started to miss a little on start up, but not stalling,
Post #431004 Sat Jul 19 2014 8:37pm
