Home > Faults & Fixes > Transmission Fault |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8847 |
I wonder if the removal of the battery for 2 weeks has caused the transfer box control module to forget its calibration? You should probably get it looked at by a suitable garage in case it's something more involved though.
Obviously, this may have nothing to do with the error so it's probably best to speak to a garage first. The alternative is to make sure the battery is in good shape - a dying battery can throw up any number of odd error messages... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Sep 25 2013 6:52pm |
franciscolalas Member Since: 27 Mar 2012 Location: Portugal Posts: 28 |
Thanks for the reply,
Wed Sep 25 2013 8:26pm |
New transmission ECU and new actuator motor solved the problem.
Sun Oct 06 2013 3:49pm |
Are you sure it was the transmission ECU that was changed and not the transfer box ECU? The transfer box ECU is in the engine bay behind the battery and can easily be drowned if the engine bay is washed because the water protection isn't very good. The transmission ECU is actually inside the gearbox so to change it requires draining the box, then the ECU change then refilling the box with £200+ worth of special ZF transmission fluid. 2008 MY Java Black TDV8 HSE
Sun Oct 06 2013 8:49pm |
Yes, it was the transfer case ecu that was replaced. |
Sun Oct 06 2013 9:14pm |
Well I'd have a frank discussion with your friend then. Looks as if he may have got the ECU wet when he washed the engine bay. The other parts probably didn't need to have been changed but franchised dealers do tend to change multiple parts first without going step by step. 2008 MY Java Black TDV8 HSE
Sun Oct 06 2013 9:29pm |
They first changed the motor which they tested first and was faulty.
Mon Oct 07 2013 12:19am |
marinj Member Since: 02 Oct 2013 Location: Barcelona Posts: 1 |
Hi, I am sharing my experience, a few years later this post, in case it can help others. (05 RR Sport)
Tue Jul 24 2018 12:23pm |
seelandi Member Since: 16 Aug 2015 Location: Germany Posts: 4 |
The described procedure from RRSTDV8 has fixed my RRSTDV6 (2005) completley!
Sat Oct 06 2018 3:53pm |
