Home > Faults & Fixes > Transmission Fault
franciscolalas
Transmission Fault
After changing my alternator and front diff I got the following fault message:
Transmission range chane not available.
I connected my obd reader and the error is 0902 clutch actuator-circuit low.
The battery was disconected for 2 weeks prior to new alternator fitting.
Any clues?
Thanks in advance.
Post #396150 Wed Sep 25 2013 4:02pm
I wonder if the removal of the battery for 2 weeks has caused the transfer box control module to forget its calibration? You should probably get it looked at by a suitable garage in case it's something more involved though.
The method for calibrating the transfer box control module (on the D3 at least) is:
Quote:
Clutch and Range Change Mechanism Calibration
In order for the range change mechanism to function correctly, the transfer box control module must be calibrated to the
mechanical dimensions of the transfer box that it is connected to.
This procedure will need to be followed if one of the following occurs:
. The vehicle is first assembled
. The switch is changed
. The transfer box control module is changed
. The transfer box or range position sensor is changed
. Vehicle or transfer box control module fault has caused the transfer box to revert to an undefined range.
Calibration can be carried out using the service tool or by following this procedure:
. Switch ignition to position II without the engine running
. Select automatic or manual transmission neutral
. Depress the throttle pedal fully
. Press and hold the range change switch for 5 or more seconds to allow calibration to start
. When the calibration is heard to start, the switch and throttle pedal can be released
. Upon adopting high range, start the engine and wait 30 seconds while the first calibration of the clutch in high
range is done. While this calibration process is in progress, no shifting is accepted
. Switch ignition off and wait 15 seconds
. Start engine
. Perform a range change to low range. Wait 30 seconds while the first calibration of the clutch in low range is done.
. Range and clutch calibration is now complete.
Obviously, this may have nothing to do with the error so it's probably best to speak to a garage first.
The alternative is to make sure the battery is in good shape - a dying battery can throw up any number of odd error messages... 2012 SDV6 - it's missing a couple of cylinders
Post #396174 Wed Sep 25 2013 6:52pm
franciscolalas
Thanks for the reply,
No luck with the calibration, so tomorrow I will go to a LR dealer to see what they say about the error codes,
ECU, actuator motor, solenoid or position sensor one has to be!
Regards
Post #396183 Wed Sep 25 2013 8:26pm
franciscolalas
New transmission ECU and new actuator motor solved the problem.
Now I have a dilemma... left the car in a friend's garage to change the alternator and front diff and he returned the car with the transmission fault, 30 miles more on the odometer, the terrain response knob was up and they washed the engine bay.
He wasn't able to fix the fault so I left the car in the Land Rover dealership to solve the problem.
Who do you think should pay the bill at the dealership?
Regards
Post #397410 Sun Oct 06 2013 3:49pm
Paddi
Are you sure it was the transmission ECU that was changed and not the transfer box ECU? The transfer box ECU is in the engine bay behind the battery and can easily be drowned if the engine bay is washed because the water protection isn't very good. The transmission ECU is actually inside the gearbox so to change it requires draining the box, then the ECU change then refilling the box with £200+ worth of special ZF transmission fluid. 2008 MY Java Black TDV8 HSE
Post #397433 Sun Oct 06 2013 8:49pm
franciscolalas
Yes, it was the transfer case ecu that was replaced.
Post #397437 Sun Oct 06 2013 9:14pm
Paddi
Well I'd have a frank discussion with your friend then. Looks as if he may have got the ECU wet when he washed the engine bay. The other parts probably didn't need to have been changed but franchised dealers do tend to change multiple parts first without going step by step. 2008 MY Java Black TDV8 HSE
Post #397442 Sun Oct 06 2013 9:29pm
franciscolalas
They first changed the motor which they tested first and was faulty.
Tomorrow I will talk to him and see how things are going to be solved.
Thanks
Post #397457 Mon Oct 07 2013 12:19am
marinj
Spain 2005 Range Rover Sport TDV6 HSE Zambezi Silver
same issue here, recommendation from LR to change transfer!
Hi, I am sharing my experience, a few years later this post, in case it can help others. (05 RR Sport)
Same inicial problem, alternator gone and loads of error messages once the new one was fitted. My local garage changed the alternator and managed to get rid of most of them apart from a transfer and suspension errors (see picture attached). He could get no further and recommend me to take it to the official LR garage to diagnose these errors.
Mechanically the car drove fine, apart from auto-activating the hand break every time I stopped and shifted to P. After "much analysis" LR said they couldn't reconfigure the transfer so I have to replace the whole transfer box...a 4500€ bill Big Cry
I check on different posts, including this one, for others with the same problem...but above all to me there was something wrong on their reasoning: the car was driving fine, with no mechanical problems before the alternator issue and after the electric failure I have to change a major mechanic piece? I am not an expert but surely other possibilities have to be tried first...
Cutting a long story short, went back there and I said I won't pay that much unless they could demonstrate it wasn't an electrical problem first. So they went back to work with their diagnostic tool and finally managed to eliminate the transfer issue (just by trying several times apparently). The suspension error is still there, lets see if they don't ask me now to change the whole suspension system Laughing
It seems official LR garage preferred to go for the easy ride on your wallet instead of getting to the bottom of the issues. They fail to understand that as important as getting new customers is to keep existing owners happy. I love the car and I would buy RR again...only if I could trust people who are supposed to keep it in good shape.
Post #561933 Tue Jul 24 2018 12:23pm
seelandi
2005 Range Rover Sport TDV6 HSE Tonga Green
The described procedure from RRSTDV8 has fixed my RRSTDV6 (2005) completley!
...tank YOU!
Post #566376 Sat Oct 06 2018 3:53pm
