Home > Maintenance & Modifications > Groaning sound from front suspension???? |
BRY460 Member Since: 23 Apr 2013 Location: Hindley Green Posts: 8 |
Hi,First post so be kind to me.
Sun Jul 28 2013 8:34pm |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Sounds like ARB bushes to me. FF 4.4 V8 Soooo looking forward to this bad boy
Sun Jul 28 2013 8:50pm |
Hi thanks for the quick reply but what are the ARB bushes (sorry for my ignorance)and bad spelling |
Sun Jul 28 2013 8:53pm |
AntiRollBar bushes....ARB |
Sun Jul 28 2013 9:13pm |
Hi, can the tracking be done at any tyre place or is it Land Rover only,does the wheel alignment have to be done when the lower arms have been replaced also Land Rover or anywhere ? Thankyou for your input. |
Sun Jul 28 2013 10:06pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
yes your wheels will be all over the shop who changed the arms did they not do it
Sun Jul 28 2013 10:11pm |
The guy that did the work,works for the car dealer that I bought it from,dont know if he did the tracking after or not I will phone tomorrow to find out.As for the wheel alighnment do you mean a 4 wheel alighnment or a garage that knows what they are doing. |
Sun Jul 28 2013 10:15pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8856 |
Where ever you go to get the wheel alignment done, make sure they can put the vehicle's suspension in tight tolerance mode while they do the work. 2012 SDV6 - it's missing a couple of cylinders
Sun Jul 28 2013 10:17pm |
Best to get the full alignment done camber toe tracking x4
Sun Jul 28 2013 10:20pm |
What difference dose that make My car was just left running as they did it |
Sun Jul 28 2013 10:22pm |
Thanks to you all for your replies,I will endevour to get it sorted and I will come back to you with the outcome.. |
The suspension system has two sets of tolerances. In normal mode, the system will ignore a wheel that is up to 15mm (I think) high or low. This means that any two wheels could be "out" by 30mm relative to each other. As suspension moves the camber changes (the wheelbase changes too between rides heights too by the way). Tight tolerance mode has a tolerance of +/- 5mm (I think). If the vehicle were to be set up with the maximum normal tolerance, it could be a long way out when driven on the road. Any tyre place should have the necessary means to activate tight tolerance mode. If not, you have to ask why not. My local place recently bought a 4 wheel alignment rig. When I asked for a price he said he couldn't do it yet because he couldn't yet access tight tolerance mode on LR products. This is the sign of a good company and the reason I've been using them for years. As I have the IIDTool I could set it to TTM myself and they did the work. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Jul 29 2013 1:04pm |
michealewk Member Since: 23 Jul 2013 Location: ireland Posts: 9 |
I think mine are gone too how do i know if mine has ACE or not |
Mon Jul 29 2013 2:50pm |
Took it to Kwikfit this morning,,they just did it in normal mode using the Hunter system they did not ask about tight tollerance mode!They did say though that because I had just had the lower arms done that the bushes may settle a little so take it back in a couple of weeks for a re-check and adjust free of charge.Tghe camber,toe and tracking was a mile out with one reading not even on the chart.Still got a small groaning noise on right hand bends but I think it is coming from the offside bearing now,may swop it for the one that I had replaced as I suspect that that one may be OK.cant do any harm as its not a massive job to do.The cost from Kwikfit....£64.90 for the front and rear alignment,the back was also out but not by much..... |
Mon Jul 29 2013 4:49pm |
