Home > General (L494) > Dynamic Response on which model ? |
If you have Terrain Response 2 Auto it will have Dynamic mode...it will be there - the configurator isnt that good...just download the catalogue Mike
Thu Apr 04 2013 6:18pm |
DBA Member Since: 20 Mar 2013 Location: Skopje Posts: 51 |
I think he meant Dynamic Response Program, which uses the air suspension to help reduce roll. TR Dynamic mode i guess is used to stiffen suspension and steering to sharpen the drive on demand as on the Evoque. It would be more usefull, if LR had more infornation on these technologies and provude some concepts if they work. Maybe some instructionall videos... |
Thu Apr 04 2013 7:18pm |
I know, which is part of the terrain response system (as is the same on the current cars ) Mike 2014 Facelift Discovery |
Thu Apr 04 2013 11:52pm |
Laurent T Member Since: 04 Apr 2013 Location: Paris Posts: 2 |
Thank you for those feedbacks. Indeed the catalogue is showing some options and details you cannot find in the configurator. Dynamic verisons include as standard the active body roll control and if you spec an HSE with the SDV6, you can get as option the On / Off Road Pack which includes twin speed transfer box, Terrain Response® 2 Auto (including Dynamic program), Dynamic
Fri Apr 05 2013 8:52am |
The UK usually gets more and better specs, for a number of reasons. I cant say the specs of the new RRS impresses though Mike
Fri Apr 05 2013 4:47pm |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
Nope! Rubbish spec's for such an expensive vehicle!
Fri Apr 05 2013 4:54pm |
I think you missed my point in the above post or my general points.
Fri Apr 05 2013 5:20pm |
Dickie Member Since: 27 Mar 2013 Location: Hampshire Posts: 200 |
What are these "hotfire" engines and why do you think they'll impact resale of the early 2013 RRSs? Are they significantly better (more powerful/economical)? |
Fri Apr 05 2013 5:49pm |
Hotfire engines will be specifically built for the 'new' LR range and will be placed in all their models from 2014. LR are building a new engine plant that will only manufacture these engines.
Fri Apr 05 2013 7:25pm |
I doubt that to be honest - yes JLR are building a new plant in Wolverhampton to make its own engines, but this isnt a new concept and to say values of the current will tumble because of that is a little extreme Mike
Sat Apr 06 2013 10:10am |
If given the choice which model would you buy - the new up engined one with a 9 speed box or the old 8 speed SDV6?
Sat Apr 06 2013 10:35am |
Thats not true either...the UK is still one of the most significant markets
Sat Apr 06 2013 11:27am |
You are not an ex Crab Officer are you MSE?
Sat Apr 06 2013 12:08pm |
i would comment if i had any idea what you meant Mike
Sun Apr 07 2013 1:07pm |
