Home > Technical > Battery Drainage Unfixable at Land Rover |
One more shot in the dark.......... in the very early days of RRS there were problems like this that were traced back to the earthing strap for the gearbox - it had come loose and fallen off. Freelander2 also suffered this problem at one stage. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Apr 02 2013 3:46pm |
My money is on faulty electornic in the alternator. |
Tue Apr 02 2013 6:18pm |
TIAB Member Since: 01 Apr 2013 Location: United Kingdom Posts: 8 |
I have the same problem, mine exists when I have opened and closed the doors a few times, getting kids seats in and out and alike. - I will be checking the tailgate switch.
Tue Apr 02 2013 7:26pm |
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 152 |
I wonder about the brake light switch? SWMBO reported that the brake lights were on dimly when she hopped out of the car after it failed to start. I know that this switch has caused other issues and is a fine quality Ford part My car has just been returned again with a shrug of the shoulders and "we cant find anything wrong". SWMBO owns this car I get to drive occasionally |
Wed Apr 03 2013 7:52am |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 |
This all getting rather frustrating.
Wed Apr 03 2013 10:01am |
Ahh because the law in OZ doesn't require them to. Went as far as barristers LR are doing all they are legally required. We have no real recourse The law is very weak in this regard in OZ All they have to do is "fix it" as per what they believe is fixed. To go further requires court cases etc which are very expensive and not guaranteed results. SWMBO owns this car I get to drive occasionally |
Sun Apr 07 2013 8:09am |
K80tcg Member Since: 29 Mar 2013 Location: Verwood Posts: 25 |
Did you get this sorted, I have the exactly the same problem.
Tue May 14 2013 7:58pm |
He did - but posted it on another thread - see this link http://www.rrsport.co.uk/forum/topic30527.html The upper tailgate switch is easy to fit but strongly recommend taking off the upper tailgate trim panel so you can access the switch with less chance of damaging the thing when you install it . Be prepared to find all sorts of filth and rust under the trim panel. (apologies if you already knew all that). 2008 MY Java Black TDV8 HSE |
Wed May 15 2013 12:50pm |
Tailgate switched repalced at land rover however same problem persists.
Fri May 24 2013 12:13pm |
Harry have you changed the battery.
Fri May 24 2013 12:22pm |
Battery replaced still same problem now going through litigations with LR!!
Tue May 28 2013 9:07pm |
The main issue now is that the Nav screen and radio freeze and do not turn off at times. |
Tue May 28 2013 9:09pm |
Rangiesport06 Member Since: 29 Dec 2014 Location: Dandenong Posts: 1 |
I have a RRS 06 that has a battery drainage problem! I have worked out the navigation unit is coming on when the car is locked. Can someone help me with this problem Is there a way I can deactivate the navigation? Please help!!! Sick of getting up in morning not knowing if the car will start |
Mon Dec 29 2014 7:28am |
