Home > eBay & Bargain Spots > Interior led upgrade |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
It makes it easier to do the glove box light if you take the unit out using this guide rather than attempting to replace the bulb in-place. |
Wed Jan 09 2013 2:49pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
Luckily there's a helpful guide (link is in the definitive 'how to' thread in the technical section)
Wed Jan 09 2013 2:57pm |
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 |
Any ideas on how to change the Side lights as I had a quick look and quickly closed the bonnet again when I thought I may need some tools. |
Wed Feb 20 2013 10:02pm |
MisterAdam Member Since: 03 May 2012 Location: Liverpool, UK Posts: 352 |
Piece of cake pal, the headlight units have got a round black cover about the size of a mug/glass/cup coaster, unscrew that then feel about for the sidelight, pop that out, swap bulb over, turn the sidelight on to check you've got the LED in the right way (they generally only work one day, if it doesnt work then turn it 180 degree's and put it back in) and in true Haynes fashion "refitting is the reverse of removal" Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi Previous: Mercedes CLS, BMW 330cd M sport, Nissan 200sx, Impreza STi, EP3 Civic Type R |
Thu Feb 21 2013 9:54am |
You'll have to remove the headlight to get to the sidelight cover. Follow this vid on how to remove headlight, it's straight forward.
Thu Feb 21 2013 10:38am |
I didn't have to remove the headlight to get to the sidelight in order to change the bulb, doing that seem's a little extreme when there's a removable access panel on the back of the headlight unit Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Thu Feb 21 2013 11:15am |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 |
I'm removing most of the LEDs inside. Think it looks too blue-y and the normal bulbs looked better IMO
Thu Feb 21 2013 1:49pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
I'm in a similar camp big pimp and recently changed mine patially back too, although I've changed the overhead ones back to standard and left the LED's in the door puddle lights and footwell/boot. ON THE WAY: BMW F21 M140i
Thu Feb 21 2013 1:59pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
I only changed the four door puddle lights internally. It gives a better view of what's on the ground before you step out. I think LEDs would be too harsh for the rest of the interior fittings.
Thu Feb 21 2013 4:34pm |
The only way I could get to the panel was to remove the whole headlight unit from the vehicle - the panel is at the bottom of the unit. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Feb 21 2013 4:35pm |
Yep, forgot about the numberplate ones, I've left those as LED too Can't make my mind up on the side lights..... ON THE WAY: BMW F21 M140i MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ) GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
Thu Feb 21 2013 4:42pm |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 |
Anyone know why the sidelights always looks blueish while the same bulb looks white in the interior??
Fri Feb 22 2013 12:40am |
The interior fittings have white plastic in them to reflect the light. The sidelights are mirrored. I can only assume that the white plastic takes the edge off of the blue tint whereas the mirror finish just reflects the blue. 2012 SDV6 - it's missing a couple of cylinders
Fri Feb 22 2013 1:01am |
Thanks guys |
Fri Feb 22 2013 1:02am |
