Home > Maintenance & Modifications > L.E.D DAYTIME RUNNING LIGHTS |
StevoD Member Since: 01 Nov 2012 Location: Bromsgrove Posts: 42 |
Hi there JEDS_SDV6, welcome to the forum, I think you'll find it of interest, as a new member I certainly have. Anyway, you're asking a question that I asked when I joined (must be a common thought) and if you have a look at this thread you'll see that it's pretty much been discussed to death.......with polarised views on the topic !!! http://www.rrsport.co.uk/forum/topic27810.html?highlight=drl If I'm in any way wrong I'm sure somebody will steer you in the right direction. Regards MY12 RRS SDV6 HSE Santorini Black with piano black wood and truffle leather Hawke tips and all black grill Privacy glass Gone: too many to mention !! Last edited by StevoD on Mon Jan 07 2013 7:07pm. Edited 1 time in total |
Mon Jan 07 2013 7:04pm |
The current model RRS doesn't have DRL's, they are called LED signature lights, your dealer can set them to come on when the ignition is switched on but your rear lights will also be on, there isn't and option to have just your front LED lights on. This will change on the 2014 RRS. But as posted above in the link you can have them fitted.
Mon Jan 07 2013 7:06pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8857 |
I wonder if it might be possible to make the front sidelights come on whenever the ignition is on irrespective of the light switch's position i.e. run a constant live to them. If one could, and one fitted a suitable LED bulb then a DRL effect would be achieved without having to run the rear lights too. 2012 SDV6 - it's missing a couple of cylinders
Tue Jan 08 2013 8:54pm |
I'd be intrested to know if the front bulbs in the LED signature lights can be upgraded to brighter bulbs ie Audi/volvo brightness |
Tue Jan 08 2013 9:28pm |
