Home > General > RRS tdv8 engine won't run
Page 2 of 3 <123>
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
In which case the boys at northeastern are the way to go Thumbs Up
Failing them I use Ripon Landrover, despite living less than a mile from strats.
Nik
Jamma88 wrote:
I'd rather have my leg off than go to stratstone haha
 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #367602 Mon Dec 24 2012 10:56pm
Jamma88
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I use a place called falcon performance but can't get in there till 2nd of jan
Post #367603 Mon Dec 24 2012 11:02pm
Nik
Try northeastern they know sports inside out.
http://www.northeastern4x4.co.uk/
Nik 2015 Golf R DSG
Post #367604 Mon Dec 24 2012 11:10pm
Jamma88
Tried bleeding the fuel valve this morning Christmas morning under the bonnet lol still not starting :/ merry Christmas ppl
Post #367609 Tue Dec 25 2012 11:41am
Join the RAC or AA as a christmas present to yourself Thumbs Up
Post #367619 Tue Dec 25 2012 4:26pm
Jamma88
Tht would just be greedy I bought the car as my crimbo present lol
Post #367620 Tue Dec 25 2012 4:32pm
SRE
Spain
Remove the turbo hose at the engine inlet manifold end, see if the will engine start, if it does then check the remaining turbo pipes for de-lamination, the inner wall of a turbo pipe can come unbounded from the outer layer and block air to the engine. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #367621 Tue Dec 25 2012 4:32pm
SRE
Spain
Example of delamination from a Disco 2 TD5
Post #367623 Tue Dec 25 2012 4:35pm
Jamma88
Ill havea check of tht I'm abit of a novice when comes to mechanics do u know where in the engine the turbo hoses are located ??
Post #367624 Tue Dec 25 2012 4:38pm
FF1078
I've seen this on 2 TD5 intercooler hoses,the inner lining of the hose comes loose from the outer,then when you ask the engine to rev it sucks the inner lining of the hose together and therefore strangles the engine of air,this then causes tons of black smoke and the engine cant breath so packs in,as someone else stated, try disconnecting the inlet hoses from the engine and see if it runs
regards Nick 10 TDV8 Santorini
Post #367627 Tue Dec 25 2012 6:36pm
Jamma88
Right lads I've got it started took intercooler pipe off and she started intercooler blowing smoke and oil out when trying to accelerate and will only accelerate to 3000 rpm are my thoughts right and my turbo has gone? Big Cry
Post #367630 Tue Dec 25 2012 7:07pm
Nik
As you've only had it a week take it back to where you bought it or was it a private sale?
 2015 Golf R DSG
Post #367638 Tue Dec 25 2012 10:33pm
Jamma88
Private Big Cry
Post #367640 Tue Dec 25 2012 10:41pm
SRE
Spain
Remember, she will NOT rev as easy as with the turbo pipe disconnected you are running the engine minus the turbo. However the fact that she will now run is a good sign.
Next option would be to replace All the turbo pipes and clean the intercooler out.
Then try again, if that fails, then sorry, but it's a dealer visit. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #367651 Wed Dec 26 2012 10:05am
Jamma88
Is a nightmare sick now am goin on holiday in 4 days so a. Just gunna leave it with the farther and let him sort it and just pik it up when I get home along with the big bill lol
Post #367652 Wed Dec 26 2012 10:21am
Page 2 of 3 <123>
