Home > Maintenance & Modifications > Hardwiring Blackvue Power Saver
Page 1 of 3 123>
muddywheels
Milk Float Man
Ok - here are my hardwired photos Thumbs Up
First drop glovebox pressing down on side catches as you pull - takes a bit of effort to push down catches Rolling Eyes
You can see plug is left in glovebox for easy disconnecting when parked in garage Thumbs Up
You can now get access to fuses to fit piggybacks Bow down
I used 52 - cigar lighter for switched feed and 48 - trailer battery supply for permanent feed Very Happy
UPDATE -Some dashcam manufacturers changed wire colours from MAY 2016 so check the label/instructions as they now vary
http://www.chameleondirect.co.uk/wordpress...lours-etc/
Hope this helps Cool Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #360693 Wed Oct 24 2012 10:26am
Thanks for that muddy, very helpful Thumbs Up
Post #360694 Wed Oct 24 2012 10:36am
muddywheels
Milk Float Man
Glad to help Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #360696 Wed Oct 24 2012 10:43am
Rudskibaliblu
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
Cheers muddy, piggybacks hopefully should arrive in morning Thumbs Up
Though having a few issues with the replay being jumpy, is this just to do with the resolution HD settings Question Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Here 110 black edition defender.
Post #360793 Wed Oct 24 2012 9:55pm
muddywheels
Milk Float Man
I have found quicker transfer with the supplied usb adapter than sticking the sd card in the computer card reader Shocked
Didn't expect that Rolling Eyes
Playback seems ok to me doing it this way though Thumbs Up
Sorry forgot to say got mine on HD/15 frames - 2nd setting down Embarassed Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #360795 Wed Oct 24 2012 9:59pm
aljo
where is the best place to get the piggy back fuses from Thumbs Up
Post #360796 Wed Oct 24 2012 9:59pm
muddywheels
Milk Float Man
I got these - delivered next day free Thumbs Up
http://www.ebay.co.uk/itm/2-X-MINI-FUSE-AD...2286530638 Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #360798 Wed Oct 24 2012 10:01pm
aljo
cheers mate Thumbs Up
Post #360804 Wed Oct 24 2012 10:29pm
Hi muddy, just a quick question, when hard wiring your camera into the fuse box, did numbers 48 & 52 already have a fuse in place? Reason i ask is because mine has and i don't want to take them out only to find ive disconnected something and then find something isnt working. Big Cry I find it strange that if they are spare ports then why have they got fuses in Question Confused
Many thanks in advance
Post #360876 Thu Oct 25 2012 3:47pm
Rudskibaliblu
Might be wrong on this Ady but think you take the fuse out. plug in the piggyback and then put the fuse into that, and then connect the wire to the powermagic wires sure somebody will correct me Thumbs Up Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Post #360886 Thu Oct 25 2012 5:29pm
Rudskibaliblu
Thanks Muddy Ill give it a go Thumbs Up Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Post #360887 Thu Oct 25 2012 5:31pm
aljo
Ive just bought a DR400G-HD v2 the firmware on it is 1.011 latest firmware apparently is v 1.040 ! when i upgrade to v 1.040 and put in camera it tells me its the wrong model ? any ideas chaps Thumbs Up
Post #360932 Thu Oct 25 2012 10:57pm
Yes thats correct, thanks Ruddy, but ive found you need to put two fuses into the piggyback for it to work properly Confused never known that before on a piggyback, did you have to do the same Muddy? I thought the piggyback was faulty.
Post #360951 Fri Oct 26 2012 10:15am
Ive come to the conclusion that the power magic must be faulty Crying or Very sad My camera won't power up with this installed, so ive taken the power magic out and powered it up to a battery direct and it won't power up, it only flickers. Confused
Post #360964 Fri Oct 26 2012 11:59am
Rudskibaliblu
Piggy backs are down at the post office because nobody here to sign for them Evil or Very Mad hopefully get them in the morning and have a go. Maybe stating the obvious here but have you formatted the SD card Question had to do mine as the footage kept missing sections out. Going to check it again tonight. Now gone Orkney grey SDV6 HSE with body style kit contrast stitch ebony leather, privacy, black piano, 22" Lowenharts for summer, 20" with Leon LTZ for winter.
Post #360989 Fri Oct 26 2012 4:02pm
Page 1 of 3 123>
