Home > Technical > P132E Fault code |
After a spirited drive back from the NEC caravan show at the weekend I was happily tracking a DB7 up Birdlip Hill (for those who do not know it, it's a steepish climb on the A417 off the M5, with a roundabout 3/4 the way up it, and another duel carriageway on to the top). and we were bowling along pretty well when i got a engine fault bong
Tue Oct 23 2012 1:20pm |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
yup, my indie put in on a ramp, and sprayed silicone grease onto both of them, its not done it since 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Tue Oct 23 2012 9:35pm |
RRS gone
Tue Oct 23 2012 10:08pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
There is a modified rod and bolt available. It would be worth freeing it off first, and if its OK, have the new rod fitted.
Fri Oct 26 2012 6:51pm |
Well it finally did it again on Saturday. (P132E error recorded, I'm assuming the "E" refers to which turbo it is?)
Tue May 21 2013 1:54pm |
Both can be done with turbo's in situ
Wed May 22 2013 7:04am |
Ideally, yes.
Tue Aug 27 2013 12:51pm |
TEV Member Since: 27 Aug 2013 Location: london Posts: 2 |
Thanks Mikey fingers x all done .. |
Thu Aug 29 2013 8:51am |
Did it fix it? |
Fri Aug 30 2013 6:42am |
mees Member Since: 17 Jul 2009 Location: bru Posts: 45 |
Hi have the same problem and the same fault.
Sat Aug 02 2014 8:53pm |
Went to the dealer in jena germany
Wed Oct 01 2014 6:34pm |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
Would an MY2010 TDV8 have the modified rod and bolt already fitted or did LR never update them? I don't have a problem but I am keen to avoid one. |
Wed Oct 01 2014 6:47pm |
Mine is december 2009, so MY 2010 |
Sun Oct 05 2014 6:25pm |
brgjohn Member Since: 27 Apr 2016 Location: somerset Posts: 7 |
Mine is an '05 tdv6 , how do you access the actuator rod?, taken off the heatshields, looked from top and underneath, can just see one end ! |
Sun Jun 19 2016 3:30pm |
