Home > Technical > How to switch off air con on MY12 RRS HSE? |
Have an early night and try some bedtime reading of your manual. Then in the morning you can tell us all if its possible But i don't think it is |
Sun Jul 08 2012 9:34pm |
The Red One Member Since: 30 Jun 2012 Location: Somerset Posts: 53 |
Have read the manual already and it says to just press it to switch it off, but it does not. I'll check with the dealer during the week if no one is able to advise on the forum.
Sun Jul 08 2012 9:46pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Why do you want to turn it off? The point of climate control is that you set the temperature and it just maintains that temperature. 2012 SDV6 - it's missing a couple of cylinders
Sun Jul 08 2012 11:43pm |
Meerkat Member Since: 30 Jun 2012 Location: Derby Posts: 10 |
Mon Jul 09 2012 12:09am |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
Auto controls the selected temperature which needs heat from the engine and cold from the air con compressor, depending on outside temperature. No air con means no control so it must be on in auto mode. In cooler temperatures although heat is required the compressor chills the incoming air to condense the water out of it. This helps to reduce condensation forming on the inside to the windows.
Mon Jul 09 2012 12:41am |
rstebbings Member Since: 16 Feb 2012 Location: Northallerton Posts: 216 |
This has been bugging me to as the Auto button on on my old 08 RRS never turned on the AC. |
Mon Jul 09 2012 8:03am |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
If your worrying about mpg that the aircon uses the RRS might not be the best car to have |
Mon Jul 09 2012 8:38am |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
I looked on line and if you turn your air con off then you can expect about 45-50 mpg.
Mon Jul 09 2012 9:07am |
With AC off the auto button only controls the heat output and fans, so not air conditioning just heating control. Having the AC off in hot weather means you may be roasting in the car, but allegedly get up to 45-50 mpg. |
Mon Jul 09 2012 11:33am |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 497 |
The site I looked at quoted mpg for RRS of 60 plus with aircon off |
And if you let it roll down the hills it goes up to nearly 70mpg. Honest.
Mon Jul 09 2012 12:13pm |
On. more serious note on my vintage 2011 I can off the auto aircon by turning the knob anti-clocwise once or two clicks but then i find all steams up so back on it goes |
Mon Jul 09 2012 12:19pm |
I'm not bothered about the MPG (45-50 is a dream), if I were I would have a different selection of cars to what I have sitting on the drive currently, for me it is more to do with why it is on in the first place and why it wasn't on the old RRS |
Mon Jul 09 2012 2:25pm |
The Red One, sorry mate I have an earlier car so can't really help. Seems strange to me though if you can't turn it off when you want to. Good old Land Rover. MY16 AUTOBIOGRAPHY Indus silver with some toys
Mon Jul 09 2012 3:38pm |
