Home > Technical > sat nav issue
kieltdv8
Scotland 2007 Range Rover Sport TDV8 HSE Java Black
sat nav issue
Hi all
Anyone have this problem?
Input a postcode- nav then confirms the position(correctly) on the map,but when it calculates the route the destination is totally wrong.
cheers Kiel
Post #342711 Sun May 06 2012 9:42am
timcom0
Re: sat nav issue
check on first screen that the counr=try hasn't changed, don't know how it does it but i had it once
just acces the first screen and set to uk should sort.
Post #342717 Sun May 06 2012 11:50am
Bradders
I gave up on the built in satnav years ago - my Garmin on the other hand is always spot on. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #342719 Sun May 06 2012 11:56am
kieltdv8
Thanks TC
Funny you should say that I've always had probs with the nav(always found it OK as long as you knew where you were going Laughing ) I tried the old reboot thing (disconnect the battery and connect the leads together for a couple of minutes.
this consequently defaulted back to Belgium which i reset. I've also tried recalibrating the default position but didn't help.
The nav finds the location OK from the post code, it is when it calculates the route it all goes awry
most frustrating Kiel
Post #342721 Sun May 06 2012 12:02pm
kieltdv8
Yeah Bradders
But it P Censoreds you off when you know the OE kit must have cost a fortune to install Kiel
Post #342722 Sun May 06 2012 12:05pm
neildurno
Anyone know where to get a cheap disc with updated maps? Thanks Range rover sport 3.6tdv8
Mitsubishi lancer evo 9 fq 360
Landy defender 90 tdi
Post #346431 Sun Jun 10 2012 11:00am
