Home > General > how do I remove the door mouldings for painting?
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
Hi guys
the spray man is doing my plastic door mouldings for £150 to continue the coding exercise but has asked me to ask you guys if anyone had removed the door mouldings? I am sure he is very capable of working it out himself but its always good to hear experience from others in case any snags were found.
also he suggested i buy some spare clips as he expects that a few may snap as the mouldings are removed, so is this a LR only supply?
Cheers as always TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control
Post #335383 Tue Mar 06 2012 9:41am
From memory, on the rear doors, there is a little grub screw holding the trim in place on the return end of the door when opened unscrew this before attempting to remove trim, then you give the trim a good tug as the rest of the trim is held on with push in clips, its always best to get a few new ones as spares because they sometimes break, i'm guessing the front door trims are similar Thumbs Up
Post #335388 Tue Mar 06 2012 10:46am
i think its a LR only thing for the clips, but they are only a few pence, Dan at Duckworths should be able to sort them
I believe there is a technique in taking them off, Siberianfox had a issue when her trims fell off/came loose as the retainers on the actual trim had been broke when the bodyshop removed them
Post #335389 Tue Mar 06 2012 10:48am
SRE
Spain
Yellow and White colour clips part number DYC101420
It's the same clip for the tailgate trim as well.
http://www.lrdirect.com/DYC101420-Trim-Cli...=DYC101420
£0.36 each from
LRDirect
Telephone: 01772 299817
URL: http://www.lrdirect.com
Simple job, however just take your time
One screw in rear door,
Also one screw on the front wing part as well & this part is a slide on job. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #335390 Tue Mar 06 2012 11:04am
sherlock
Thanks guys, i thought it would be simple TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #335391 Tue Mar 06 2012 11:06am
sherlock
cheers SRE, was just looking for your post actually when you replied. Can you remember if theres a screw in the front door as well? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #335394 Tue Mar 06 2012 11:11am
SRE
Spain
This should give you an idea. The yellow part of the clip SHOULD stay in the door and the white part in the door cladding
Also remember to refit the rubber weather seal on the botton of the trim. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #335395 Tue Mar 06 2012 11:15am
sherlock
dood ?? Rolling with laughter Rolling with laughter
Do you remember a holding screw in the front doer mate? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #335396 Tue Mar 06 2012 11:23am
My advice
Buy a bag of clips..some will break.. Thumbs Up RRS gone
Post #335401 Tue Mar 06 2012 12:23pm
SRE
Spain
No screw in the front door, only clips Thumbs Up
sorry about the dood, using a phone to post is a pain in the buttocks, still better than your pype wurkx Rolling with laughter Rolling with laughter In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #335406 Tue Mar 06 2012 1:36pm
sherlock
1 all then by my reckoning Very Happy TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #335409 Tue Mar 06 2012 1:42pm
I make it 2-1 to SRE........how do you spell 'tailored' again sherlock...... Whistle ON THE WAY: BMW F21 M140i
Post #344331 Mon May 21 2012 1:19pm
zaphod
This is something I need to do to my RRS... the lower mouldings on the front doors are loose. Have tried giving them a thump and they click into position for a few days but then pop off again.
Looking at that picture... is the front door trim supposed to be fastened with 14 clips in total or 10... can't tell if the 2 holes at each end of the door are supposed to have a yellow clip in them or not? Just want to know so I can buy an appropriate number of replacements. Thanks Thumbs Up
Post #454376 Mon Mar 02 2015 2:25pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Just got a price here in Belfast, its £400 - £500 to get them done, would love them done for £150! Should I shop around more?
Post #454390 Mon Mar 02 2015 4:42pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I got all 4 door mouldings and wing mouldings done for £120. I did have a lot of work done ie bumpers etc etc. I would shop around that price you have been quoted is shocking Shocked
Post #454395 Mon Mar 02 2015 6:15pm
