Home > General > HDC fault - suspension lowered |
XUJG Member Since: 03 Aug 2006 Location: Left Posts: 437 |
I |
Mon Aug 01 2011 4:17pm |
Have you checked your battery? Sometimes a slowly recovering battery will trigger an HDC fault if you re start soon after it's been switched off. RRS gone
Mon Aug 01 2011 7:43pm |
ELD70 Member Since: 20 Jan 2009 Location: UK Posts: 163 |
Deffo needs a new battery or at least a full charge with a CTEK charger. |
Sat Jan 28 2012 11:35pm |
Sat Jan 28 2012 11:36pm |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 |
What should the voltage be on the battery?
Sun Jan 29 2012 9:24am |
ajp166 Member Since: 10 Jul 2011 Location: london, UK Posts: 241 |
12 Volts, 90-100 amps.... I got a Borsch one in halfords..... 100 quid roughly. I had a similar problem, was driving and suspension dropped HDC no availiable and the dash would light up with tranmission fault and park brake fault, got the battery checked and it was unserviceable.... I think with these RRS the battery needs to be in good order as there are alot of electrics to power.... I was shocked as everything in the car worked as normal..... but hey get it checked and changed. |
Sun Jan 29 2012 12:30pm |
