Home > Maintenance & Modifications > RRS TDV8 Tuning Box Connection |
kennyt0804 Member Since: 18 Oct 2011 Location: Prudhoe Posts: 12 |
Hi Guys
Thu Oct 27 2011 9:28pm |
Just under the dash right hand side of the steering wheel |
Thu Oct 27 2011 9:41pm |
The unit ive have plugs into common rail diesel electrics
Thu Oct 27 2011 9:51pm |
Never heard of any such connections.
Thu Oct 27 2011 11:58pm |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 |
If your unit intercepts the signal to the common rail, you need to locate the plug which on a TDV6 is on the front-end of the right-side rail (remove the top engine cover, rail runs along the side of the block). Not sure if the TDV8 is the same.
Fri Oct 28 2011 2:25am |
