Home > Maintenance & Modifications > RRS TDV8 Tuning Box Connection
kennyt0804
United Kingdom 2008 Range Rover Sport TDV8 HSE Santorini Black
Hi Guys
Can anyone tell me where the connector is located on the RRS TDV8 57 Plate for an Tuning box to plug in??
Cheers K T
Post #319005 Thu Oct 27 2011 9:28pm
Just under the dash right hand side of the steering wheel Thumbs Up
Post #319008 Thu Oct 27 2011 9:41pm
kennyt0804
Hi Ady Thanks for the reply
The unit ive have plugs into common rail diesel electrics
kenny T
Post #319010 Thu Oct 27 2011 9:51pm
Ah right, i understand now, bobby will be along soon to give you your asnswer unless someone else knows Wink
Post #319011 Thu Oct 27 2011 9:56pm
Bobby
Never heard of any such connections.
Doesn't your tuning box come with instructions? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #319028 Thu Oct 27 2011 11:58pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
If your unit intercepts the signal to the common rail, you need to locate the plug which on a TDV6 is on the front-end of the right-side rail (remove the top engine cover, rail runs along the side of the block). Not sure if the TDV8 is the same.
I'd be getting the instructions first though, before mucking around with fitting!
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #319032 Fri Oct 28 2011 2:25am
