Home > Technical > Parking Assist problem |
Simply get the dealer to fix - it actually sounds more like a faulty sensor than a module . 2005 Zambezi TDV6 - Gone but not forgotten
Fri Jul 08 2011 5:49pm |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 |
parking sensors has to be reset via computer
Fri Jul 08 2011 5:52pm |
THE VOICE Member Since: 08 Jul 2011 Location: Luxembourg Posts: 4 |
Thanks . So as you wrote it could be the case with my problem. Fitted the new sensor but still have to get the garage to reset the sensors?? Dam wanted to avoid another cost Thanks |
Sat Jul 09 2011 10:02am |
The parking aid module has a diagnostic connection via the medium speed CAN to enable faults to be retrieved using a Land Rover approved diagnostic system. Additionally, an on-board diagnostic routine within the parking aid module constantly monitors the system and alerts the driver to a system fault by emitting a tone from the front or rear sounder, depending on the fault.
Sat Jul 09 2011 10:15am |
Thanks for your info BOBBY.. I was told by the Land Rover dealer that my MODULE was faulty and sensor were OK!!(sorry wrote sensor on my last mail, meant to write fitted new module) I fitted the new module only to find that I had the same problem, no parking assist and light flashing. I was wondering if after fitting the new module that the system had to be reset via land Rover??? or they did not correctly diagnose the problem ?? ..Thanks |
Sat Jul 09 2011 12:35pm |
There was a revised module for the earlier cars and no, no need to reset anything.
Sat Jul 09 2011 12:44pm |
buzzer Member Since: 16 Jul 2011 Location: lagos nigeria Posts: 4 |
I have a 2009 Sport HSE, and im surprised it doesnt have any reverse cameras! they have been installed in much cheaper cars for years, Now i see that Range Rover have added cameras all around the 2011 models! Can i fit cameras on my 2009? Can i change the whole entertainment system? My satnav also does not function, due to the region im in, is there a DVD that can change the satnav settings? buzz |
Sat Jul 16 2011 11:25am |
