Home > Technical > Steering vibrations |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 |
The first thing to check is that your wheel bolts are all tight.
Fri Apr 28 2006 6:52am |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 |
Davis, my RRS has developed a slight knocking sound / sensation from the front end (steering rack, suspension mountings or somewhere around there) which is apparent at lowish speeds on uneven surfaces. Mileage is 7,000 like yours (but no service due here till 15,000). I would describe as a vibration, as it is a very low frequncy at one slight knock at each slight road imperfection. RRS TDv8 HSE Rimini
Fri Apr 28 2006 7:28am |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
Smarticus,
Fri Apr 28 2006 8:13am |
TechnoPOP Member Since: 27 Feb 2006 Location: Zagreb Posts: 3 |
My RRS has 8000 KM and it does the sam thing. I went to my dealer and they know about the problem but they have no fix. It started after 3000 KM and it's there. |
Fri Apr 28 2006 9:59am |
AdrianT Member Since: 09 Dec 2005 Location: South Posts: 10 |
Fri Apr 28 2006 12:10pm |
DAVIS Member Since: 27 Dec 2005 Location: Genoa, Nevada Posts: 134 |
Made an appointment with the dealer in Reno Nevada for Monday AM. It's a small dealership and I'm a bit concerned about their "talent pool" with regard to diagnostic skill.
Sat Apr 29 2006 4:01pm |
Sniegy Member Since: 24 Apr 2006 Location: Melbourne, Australia. Posts: 18 |
Hi guys,
Mon May 01 2006 11:33am |
Dropped of my RRS this morning and spoke with the Service Manager, nice guy however not sure he was "on top" of things. They gave me a loaner car, a '05 Freelander. I discovered that if you hold the steering wheel at 3 and 6 o'clock and bend your neck as far forward as possible no one can recognize you in a Freelander
Mon May 01 2006 10:23pm |
m5con Member Since: 01 May 2006 Location: newtownards Posts: 5 |
I've also had this knock with 1500miles on the car, they replaced the anti roll bar bushes! and it's back 400 miles later. She's goind in again! 2006 tdv6 hse Bonatti grey
Mon May 01 2006 10:26pm |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
Classic! Keep us updated if they manage to resolve it! Runner up - 2009 Best Avatar Award Joint runner up - 2009 Outstanding Contribution Award WINNER - 2008 ‘Best Thread’ Award – Beautiful Women Of The World Runner Up - 2008 Comedian Of The Year Award Runner Up - 2008’s Funniest Incident 06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods - GONE - ( |
Tue May 02 2006 9:44am |
BBlackRRS Member Since: 31 Aug 2005 Location: US Posts: 40 |
Then you obviously have an all wheel drive balancing machine or dyno which is not the most prevelant piece of machinery needed to correct these sort of things, nor are they cheap.
Tue May 02 2006 3:53pm |
Now for the rest of the story... I picked up the RRS this morning and immediately noticed "new" weights on all 4 wheels. This was somewhat aggravating as I just had the wheels balanced! So, the technician, Mike and I went for a drive on the freeway to give it a road test. Well, I'll be damned they fixed it. Mike told me there is a technical service bulletin out regarding placement of wheel weights, specifically the need to remove any stick on weights from the back side of the wheel to prevent them from cutting the brake lines. He went on to say that the RRS and Turbo are very road sensitive and the Turbo comes equiped with a steering dampner to compensate for the 20" wheels.
Tue May 02 2006 9:44pm |
how's that work then RRS TDv8 HSE Rimini Disco 4 TDv6 HSE Ipanema Defender 90, 200tdi CSW |
Tue May 02 2006 10:44pm |
[quote="BBlackRRS"]Then you obviously have an all wheel drive balancing machine or dyno which is not the most prevelant piece of machinery needed to correct these sort of things, nor are they cheap.
Wed May 03 2006 1:55am |
