Home > Technical > Logic 7 |
I doubt it, Paul. I'm no AV buff, but I expect the extra processing to perform all the 5.1/7.1 trickery is in hardware as opposed to software. I'm sure someone can give a much more comprehensive answer.
Fri Apr 28 2006 2:11pm |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
Paul, I think there is also something like double the number of speakers, not just a couple in the headlining.
Fri Apr 28 2006 3:06pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Sorry Paul, can't see L/R sticking in a better head unit for free that can be upgraded with software. Have you asked the dealer yet? TDV6 - gone
Fri Apr 28 2006 4:11pm |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
The head unit is the same. The amplifier is different. (As is the infotainment system software. If you have the "wrong" software installed, it sounds like total garbage.) The Logic 7 processing is done in the amplifier.
Fri Apr 28 2006 6:27pm |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 |
In which case grommet, I'll gladly take your Logic 7 amp off your hands
Fri Apr 28 2006 8:38pm |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 |
I think it is under the drivers seat, it is in my 'premium' D3 anyway |
Fri Apr 28 2006 9:58pm |
RAD Member Since: 23 Sep 2005 Location: In the chippy! Posts: 309 |
Although I've got Logic 7.....the sound with it switched out, is far better. I have had the software "updated" (the amp is under the drivers seat) 3 times, all without success. LR are aware of the problem, but don't seem to have a working answer. The problem doesn't affect all cars with it fitted, but quite a few.
Sun Apr 30 2006 10:16am |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
I have it in my car and it sounds great but like RAD said it's doesn't affect all cars RRS TDV6 Gone but still around
Sun Apr 30 2006 10:48am |
Already been done by JE, and you're right, it makes ahuge difference Paul |
Sun Apr 30 2006 10:19pm |
Peter Member Since: 28 Feb 2006 Location: Maidenhead Posts: 175 |
I have Logic 7 fitted and it really sounds the mutts nuts!
Wed May 03 2006 6:39pm |
To put it in perspective, if you have a duff Logic 7............its a relief to switch it off and listen to the standard setting. If its bad, its really awful. They’ve changed the amp twice, re-loaded the software three time. Maybe if I went to church........? |
Thu May 04 2006 9:34am |
For me, I don't like the Logic 7 processing effect on most content. It isn't defective... it even sounds about the same on RRS and LR3. I just don't like it. (I'm sure some may.)
Thu May 04 2006 10:00am |
I had Logic 7 in my BMW 645 which sounded wonderful, that's the reason I specified it. Driven in other RRS's that work just fine......one problem is the programming, each time its re-done, everything changes, but after a few days the improvements just melt away like.....er, sorry, just having a a senior moment. Anyway, its obviously a software problem, but no trace of getting the right answer - yet! |
Thu May 04 2006 10:30am |
