Home > General > Suspension totally failing - help |
Govette Member Since: 13 Nov 2009 Location: Canberra Posts: 41 |
I think part of the problem is the format of the error codes. These cars are one of the first to implement the ISO 14229 Standard for fault codes. Unfortunately, as it was at the time so new, I think that a lot of the software wasn't really written with it in mind and was thus just patched to comply. (Not that I'm a software guru, but there is a very interesting article on the blackbox website about it.) Mine is in the dealers with the same untrackable error causing suspension, engine, transmission shut downs etc. The thing that annoys me though is not the 'replace everything' approach, it's the 'yep, we've tested it and it's fine now' . For example, I picked mine up yesterday, with the EAS computer replaced. I was told that it had been 'fully tested' and yet I drove three minutes up the road, and full shut down. The reason? Simple. Many of the computers are not self tested upon startup, they get tested after specific variables are met, which takes time. My point is, if I know this, just from reading the information given by an aftermarket test device, how is it the 'trained' land rover expert at the dealers don't know it?
Thu Oct 14 2010 7:37am |
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 |
That was the problem they had with the suspension on mine! There were no error codes to even point them in any direction at all for where to look!
Thu Oct 14 2010 9:47am |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
Yep I know that experience first hand very well! |
Thu Oct 14 2010 10:33am |
4WheelDriver,
Fri Oct 15 2010 3:10am |
I think it was the multimedia unit in the end but there was a list of ECUs that they changed! By that time I'd had enough of paying for a 50k motor and driving a Freelander 2 for 3 months so it was bought back! Think it was resold after that so I can't tell you for sure! The list of things is at home and I'm in Marbella at the moment but I can check it when I get home and give you the list that was changed then? Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
Fri Oct 15 2010 9:10am |
Yes mate, a list of what was done and in what order would be much appreciated if you have it. I'm trying to stay positive about my $80,000 donation to the Land Rover Dealers of Australia appeal. (Although I think they are enjoying the donation about as much as I am, poor !) I've owned her for almost twelve months now, bought privately from an owner that 'never had a days trouble with it'. I did a background check during purchase, and all LR would say was that she had had 'some' warranty work done that was all 'quite normal stuff'. Since then, it's had the phantom engine, transmission, everything else fail and log no error problem. Dealers had no idea, ended up being paint on the earth stud preventing a good earth. Then is had the sagging suspension down one side. Have had both struts down that side replaced. Apparantly now it's 'within tolerance' even though if it's left for more that two days (which seems to be quite often!) you find it sitting on the bump-stops. And now it has a suspension? fault which shuts down the whole car and suggests that you would be better off walking. (Wiring resistance checked, both EAS and Dynamic Stability computers replaced, and still no joy.)
Sun Oct 17 2010 1:39am |
Thought we all could do with a bit of light hearted bantering?!!
Mon Oct 18 2010 7:01am |
Rislar Member Since: 04 Oct 2010 Location: Western Lake District Posts: 194 |
and i though i was having a bad week If it aint broke leave it!
Mon Oct 18 2010 11:09am |
RRS_bunny Member Since: 24 Jun 2008 Location: Australia Posts: 47 |
Wow, Govette, that was a bad week. Hope things are getting better.
Fri Oct 22 2010 4:03am |
You had an outcome on this yet RRS bunny?? Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
Wed Nov 03 2010 1:16am |
Got the car back on Friday. It was ok over the weekend (took it out twice) but the suspension is now quite hard. (almost like sports suspension)
Wed Nov 03 2010 1:19am |
Have the told you exactly what they've done to fix it - parts replaced, software updated etc?
Wed Nov 03 2010 2:48am |
Maybe its a more common problem:
Sun Nov 07 2010 8:29pm |
Hi all
Thu Nov 18 2010 12:21pm |
