Home > Technical > what is an ace rail ?????????? |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
Bobby you always have make us others look like total idiots
Wed Jun 09 2010 2:01pm |
Hope it all works out for you! Malaysia Boleh!
Wed Jun 09 2010 8:55pm |
Aww.. Angel! Don't say that!! Just contributing my two cents worth!! Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Wed Jun 09 2010 11:56pm |
Thu Jun 10 2010 7:09am |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 |
finally got to the butt of this , this is the ACE RAIL |
Sat Jun 12 2010 11:24am |
did pics go up ? |
Sun Jun 13 2010 3:28pm |
HST Member Since: 05 Mar 2015 Location: Kirkby in Ashfield Posts: 9 |
My 09 MY HST has leaking rear ace bar. Main stealer quoted £1600 approx to swap it. Found out the Famous Four of Louth do a repair kit for front and rear bars. Quoted £250 to do both so its going in on Wed. Will post results. Said to work in 80/90 % of all cases. Now let me see £1600 v £250 which should I try. Oh and if it doesent work it can go onto a new bar so it will not leak!! Anyone had any experiance of this fix? |
Mon May 04 2015 8:50pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
The repair kit probably just replaces the o-rings on the pipes. These are serviceable items. If it's leaking from the bar itslef then a new bar is required. And that's why the price is so high - the bar is expensive and I think it's 2-3 hours to replace if you know what you're doing and it goes well. 2012 SDV6 - it's missing a couple of cylinders
Mon May 04 2015 8:58pm |
Apparently its not replacement of the seals, which as you say are replaceable in any event. This kit apparently involves additional brackets and the like. I will find out more on Wed and try and get photos. |
Mon May 04 2015 9:22pm |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
I had the same issue with my frome ACE unit, however my Indie found that it wasnt leaking at all, and the oil was infact coming from a engine mount, appartently these are now oil filed, and damper controlled by a ecu 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Tue May 05 2015 9:54pm |
Job now done. Apparently what happens is that the bars themselves move in and out of the hydralic "can" in the middle. This can then affect the internal seals which start to leak. The kit that has been fitted to my HST consists of 4 clamps on the front bar and 2 on the rear. They reinforce the originals that move easily. Seal conditioner is then added to the fluid which of course swells the seals. I have included (I hope) which show the parts and fitting. Dont know if it works yet but a weekend dash across Germany and back will soon tell. Will report in due course. The front kit is £75 and the rear £45. 1 hour to fit and a tube of seal conditioner. So much cheaper than changing the bar.
Wed May 06 2015 6:56pm |
Interesting. First time this fix has come up as far as I know.
Wed May 06 2015 7:03pm |
My thoughts exactly Paddi. Fingers crossed that we've learnt of a cheap repair for the future... 2012 SDV6 - it's missing a couple of cylinders
Wed May 06 2015 9:27pm |
Dave435 Member Since: 14 Jul 2014 Location: Aberdeen Posts: 40 |
I've recently replaced my rear one due to it leaking. From what I've come across it's very common that they're moist but don't actually leak. Mine was leaking so I fitted a new one for peace of mind. |
Thu May 07 2015 10:12pm |
