Home > Technical > Low Beam Headlamp Bulb Retaining Clip - Part number
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Changing the nearside low beam bulb the other day and dropped the metal clip that clamps over each side of electrical block and holds the bulb in the headlamp unit.. it disappeared down some recess in the engine bay and now is completely lost...
Does anyone have the part number for this, our local dealer cannot find it and i have no desire for buying a complete headlamp unit, I have standard halogen lights
Any help appreciated
Thanks Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #256768 Mon Feb 22 2010 9:21am
Bob.
This UK diagram is supposed to cover halogen as well bi-zenon types. I can't see a clip for the halogen bulb shown only a "cover". If the part you want is there tell me what the number on the diagram is and I will look up the UK part number for you.
Post #256887 Mon Feb 22 2010 9:12pm
Zilch
Bob scanned in the page and arrowed the offending part from the manual
Its an innocuous piece of metal that retains the bulb within the actual housing on the Australian variant ..
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Another Pommie Bar Steward down under
Post #256936 Tue Feb 23 2010 9:03am
Bob.
The same set up is shown in my handbook for halogen types but sadly no sign of that clip in the parts diagram that I can see. You could try TLO (The Large One) over on DISCO3.CO.UK - Parts Manager at Yeovil Land Rover).
Perhaps some forum member - or a dealer service department - has a damaged headlamp and would donate the spring clip. Bigger picture shown below to help identifying. (Also seems to be the same clip fitted to the "extender" shown on the previous page of the manual for the high beam bulb)
Post #257049 Tue Feb 23 2010 10:38pm
Zilch
Thanks bob will do
Cheers Another Pommie Bar Steward down under
Post #257175 Thu Feb 25 2010 8:05am
stephenw
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Zilch, I think I have bad news for you. I did a search for these thingys a while back and they, at the time, were not identified as an individual item, just the higher assembly.
I did this because I have modified my lights for HID on the high beam spot and I wanted the ability to go back to standard. You can see what I did to the clips in the following link.
http://rrsport.co.uk/forum/topic6730.html
You might try PMing Ivery, as he purchased my standard lights when I changed over to the HID units (and then did the mod)
I'm just about to transfer these to my new RRS (when it arrives next month) so I WILL be careful not to drop the clips!!
Steve RRS TDV6 MY07 gone.
RRS TDV6 MY10 just arrived!
Post #257176 Thu Feb 25 2010 8:07am
Zilch
Steve i have asked ALTO to see if they anything coming back under repair/warranty that they can strip out and will ping ivery as suggested
Jim Another Pommie Bar Steward down under
Post #257177 Thu Feb 25 2010 8:27am
