Home > General > bluetooth/ PTI option |
I've just re-read your message and you are asking whether or not you can use a Bluetooth phone without the PTI option? I don't believe so.... or else why would the option exist?
Wed Sep 21 2005 11:38am |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
You need full pti option/fitted to enable use of bluetooth. I upgraded my phone to the new 6230i and although LR hav'nt launched a cradle for it yet they say it wont be long.
Wed Sep 21 2005 12:13pm |
noddy Member Since: 19 Sep 2005 Location: Leics, UK Posts: 76 |
OK many thanks chaps. So it looks like the dealer info to me at order-time was duff ("the HSE spec should be the same as the Disco3 and Bluetooth phones will work through the keypad & microphone/speaker without the PTI option")..
Wed Sep 21 2005 12:32pm |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2579 |
OK, in the Supercharged I may eventually get ( ) I will have the full fat PTI as standard and will be buying a cradle for my 6230.
Wed Sep 21 2005 2:02pm |
Not according to the manual, but I haven't got two phones to try that with. It says a wired phone always overrides any other phones paired with the car. It goes on to suggest that if you want to e.g charge a phone, whilst using another via Bluetooth that you should disable BT on the wired phone. You can have up to 8 phones paired with the car over BT apparently....
Wed Sep 21 2005 2:15pm |
No... the cradle will overide any bluetooth connected/paired phone. " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Wed Sep 21 2005 2:32pm |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
It is my understanding that you can pair five bluetooth phones with the sport, but the phone in the cradle will always have priority over the others. Its out there somewhere. Second V10 Treg on the drive at the moment. |
Wed Sep 21 2005 4:08pm |
Toodeep Member Since: 09 Jul 2005 Posts: 42 |
True, but only one at a time can ever be linked to the car. In my experience the car always chooses the latest phone used so if your partner, for example, has been out on his or her own and their phone has been found then you go out together, the car will still look for your partner's phone first. Range Rover Sport TdV6HSE in Bonatti Grey + 20" Stormer wheels (ex X5 and ML driver) |
Wed Sep 21 2005 4:26pm |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 |
Here in the US I am using a Motorola V710 (Verizon), upgraded to the latest software, mostly without hiccups via Bluetooth. A couple of times, the phone will ring but the car will not pick it up until I flip the phone open in my holster, then it's fine. So far I have had to re-pair the phone only once, otherwise I normally get in the car, start it and "Phone Attached" appears on the display. Caller ID works through the radio display, although Call Waiting and 3-Way Calling do not. Callers can hear me quite well, and viceversa. All in all, I am pretty happy with the integration, considering this phone is not on the list. Also, although it would be nice to have a cradle for it, I am wondering how many times I would end up forgetting the phone attached to it if I had one.
Fri Sep 23 2005 1:02am |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
Same as cradled... "as designed." You can, of course, turn off the voice Navigation. I guess the idea is that Navigation is a priority if you have it running; it's your annoying Navigator that can care less if you are on the phone.
Fri Sep 23 2005 2:53am |
I did (to LR North America). I also asked about future availability of additional cradles for other model phones. I got the following canned reply back, although someone took the time to write it and hopefully is passing this feeback on to the powers-that-be:
Fri Sep 23 2005 6:14am |
