| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Over-eager PDC! |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20386
Hi all,
| RRUK Joined: 10 Jun 2005 Location: Certainly In-Vogue Posts: 2239
I don't know the technicalities or settings on it, but I had front and rear PDC on the M5. Sometimes it would beep as I was exiting our cul de sac for no reason as far as I could gather. The front sensors seemed to come on when the car thinks it is being manoeuvered at slow speed, as if parking the car.
Yeah, whilst my car was beeping all around me over the weekend I was wishing for an iDrive screen with that on |
| Zipperman19 Joined: 22 Aug 2005 Location: South Florida Posts: 85
I have the same problem. Mine beeps whenever it feels like. I can be stopped at a light when no one else is there and it goes off. |
Sorry to Hi jack:
It's a Land Rover, you didn't expect it to work properly did you?!!! |
Thanks for the feedback guys. So it looks like it's just one of those things... will try and remember to turn the PDC back on again when I head for a multi-storey car park! |
| scorpio Joined: 08 Jul 2005 Location: London Posts: 142
have found the front pdc to be a complete nuisance, and with the good vision from the front I think unneccesary. Were going of at all unusual times and places and started far too early.\\\The rear pdc, is great |
| Geordiehillbilly Joined: 22 Aug 2005 Location: Newcastle Posts: 32
Strangely I've noted that the beep occurs mostly when I'm pulling up to red traffic lights. Not sure if they are emitting anything that the car is maybe picking up. Even stranger than this, I notice when I pull up or past a bus, the PDC often goes off..... |
| Toodeep Joined: 09 Jul 2005 Posts: 42
PDC seems to switch itself on below a certain speed and yes it does seem to have too great a range around 45 degrees to the front so that it responds to passing motorcycles and oncoming vehicles in an adjacent lane. If I remember the BMW (X5) system only activated once reverse had been selected (as is usually the case when entering or leaving a parking space) and stayed active until a given speed when it was reasonable to assume the manoeuvre was over. Unlike the RRS system it was otherwise off by default with a button to switch it on if required. Seemed simple enough to me! Range Rover Sport TdV6HSE in Bonatti Grey + 20" Stormer wheels (ex X5 and ML driver) |
| Esoteric Joined: 01 Oct 2005 Location: Northern VA Posts: 21 |
My only gripe is tha tyou can not disable one PDC only both at the same time. I see no need for front PDC but rear is very useful. |
