Home > Tips & Tricks > Bike Carrier |
bryanlittlefair Member Since: 03 Oct 2008 Location: Bury St Edmunds Posts: 39 |
Hey Guys,
Thu Feb 05 2009 3:46pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Thule Euroway was my choice - from somewhere like roofracks.co.uk (other suppliers available )
Thu Feb 05 2009 4:08pm |
Don't forget that for most bike carriers that fit the RRS you either need the roof bars or the tow hitch - not many bike carriers will fit on the rear hatch without causing damage to the rear spoiler paintwork 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Feb 05 2009 4:51pm |
Thu Feb 05 2009 5:20pm |
Message received MAW! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Feb 05 2009 5:39pm |
Tim has a point though as I havent really thought this through, as I dont actually have a tow bar fitted at the moment, so unless under the bumber there is some magical attachment, then if I am right and I dont wantt o have a naff one sitting on the back of the car scratching the paintwork, i will have to pay for a tow bar fitting, then the cycle carrier ... correct ???
Thu Feb 05 2009 6:02pm |
No - there is a magical attachment!
Thu Feb 05 2009 6:39pm |
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 |
OK, so I have the removable tow bar, and I also have the roof rails. For my old Lexus I used the roof rails and have two leftover Thule bike carriers. Now my question is this;
Thu Feb 05 2009 7:52pm |
Mine is something like thule euroway 485 or something if you look on that website they'll be there somewhere and newer versions no doubt - very impressed by the design and function
Thu Feb 05 2009 8:08pm |
Bryan - take yourself and a 2p coin round to the back of your car. In the centre of the rear bumper your should see a small removable section. Taking some care not to press too hard, slot the 2p piece into the palstic snap bolt heads on the lower edge of the centre section and turn 90degrees anticlockwise and the cover should pop off. Behind the cover should be a) a monster cast recovery eye attached to the chassis b) some plugs (white and black) for the towing electrics and also lower still you should see a red plastic fillet - this is the cover for the detachable towbar socket. What you need to buy is the detachable tow hook and have the trailer electrics connected and enabled (for plugging in your lighting bar!) When not in use the towbar fits into one of the slots in the polystrene moulding under the boot floor
Fri Feb 06 2009 12:26am |
If you haven't got the tow pack fitted (electrics) the parts are around £75 and take an hour to DIY fit |
Fri Feb 06 2009 9:06am |
Thanks guys for all the detailed responses, just what i needed. |
Fri Feb 06 2009 10:18am |
jonhickton Member Since: 27 Feb 2009 Location: Worcester UK Posts: 2 |
I would like to keep the rear of the car free from bike racks and fit bikes to roof. However the car has come with the Landrover rails and cross bar. does anyone know whcih bike rack to buy? I've been to Halfords today and the Thule 591 doesn't fit as the cross bars are to wide. Any ideas on adapting the Tule 591 or alternative bike racks?
Fri Feb 27 2009 2:46pm |
sorted thanks for all the other info. on this site that i failed to find before. |
Fri Feb 27 2009 3:19pm |
