Home > Tips & Tricks > Bone Dry!
RRSSS
Bahrain 2010 Range Rover Sport Supercharged Nara Bronze
Bone Dry!
Im sure this has been discussed before, but just a small tip for those that get caught out on an empty tank! I managed about 5 or 6 kms (3-4 miles) after the display read zero..
I switched off the a/c and stereo to see how long it would go but then came up to a petrol station and pulled in..
And yes, I was Censored it!
Post #202322 Mon Dec 29 2008 5:56pm
NickM
You did well - I did that with the GTC on the weekend, went down to zero - five miles or so until I go to a garage - the engine warning light came on - had to call out breakdown - and they said it was because I let it get so low - that the mix of fuel in the engine blah blah etc caused the problem......so they came out, reset etc, and was told never to do it again!
Post #202325 Mon Dec 29 2008 6:02pm
I heard that you still have a good few miles in ALL cars before you light would come on RRS TDV6 Gone but still around
Post #202333 Mon Dec 29 2008 7:37pm
A while back I got done to zero and did about 5 miles before I chickened out and got a refill.! 2005 Zambezi TDV6 - Gone but not forgotten
Post #202334 Mon Dec 29 2008 7:39pm
hit 0 miles once in the RRS while stuck in traffic - decided to turn the engine off while waiting just in case - a minute later I restarted and it then read 20miles left
Post #202342 Mon Dec 29 2008 10:50pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
....well I got down to minus 20 so there Ner Ner ....I still pushed on and hit minus 35 Exclamation
but then again, I could be an imposter and my real name is actually SP the master of spin (bullshit)
Whistle L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #202345 Mon Dec 29 2008 11:14pm
RRSSS
Well I thought of doing the same but read somewhere that switching it off and back on actually consumes more petrol than leaving it on idle. Question
A part of me wanted to keep going just so that i could hear the "pumps whirring" noises that Clarkson et. al. keep mentioning on their silly trips just before one of them runs out of petrol!
Post #202356 Tue Dec 30 2008 6:14am
Well, I have my petrol specially made for me so that it never runs out. But if it does run out, I just have to pulll into a petrol station and they see my grille and give me free petrol! Whistle
Post #202405 Tue Dec 30 2008 3:31pm
will_wonka
The real reason is (according to Jay) you have a small willy and they just feel sorry for you Whistle L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #202409 Tue Dec 30 2008 3:45pm
It's only small when Jay's around. You don't need to get him all excited at his age.
Post #202410 Tue Dec 30 2008 3:48pm
will_wonka
Misery claims that it creates his own special inverted fagina, even when speaking to GayMann....hats off, thats impressive Shocked Whistle L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #202411 Tue Dec 30 2008 3:50pm
Now I know why he's bald! Rolling Eyes
Post #202413 Tue Dec 30 2008 3:56pm
Bobby
Fuel Level Gauge
The fuel level gauge displays the fuel tank contents. When the ignition is off, the pointer returns to the empty position.
The instrument pack is connected to two tank level sensors. One sensor is located at the front of the fuel tank and the other is located at the rear. Each sensor uses a float operated MAgnetic Passive Position Sensor (MAPPS) for measuring the fuel tank contents.
Each sensor is supplied with a reference current from the instrument cluster. The instrument cluster measures the returned output from each sensor which is proportional to the amount of fuel in the tank and the position of the float arm. The inclination of the vehicle, derived from a CAN message from the Electronic Park Brake (EPB) module, is also used to calculate the fuel tank contents. The instrument cluster uses the fuel level sensor signals and the EPB module inclination signals to accurately calculate the volume of fuel in the tank and display this on the fuel level gage. The instrument cluster monitors the signals and updates the fuel level gage pointer position at approximately 20 second intervals. This prevents the pointer moving continually due to fuel movement in the tank due to cornering or braking. When the ignition is off, the pointer needle returns to the empty position.
A warning lamp is incorporated into the fuel level gauge and illuminates when the fuel tank volume is at or below 12.5 liters (2.75 Gallons) on petrol models and 14 liters (3.69 Gallons) on diesel models. This is accompanied by a chime from the instrument cluster and a message alert the driver to the low fuel condition.
The fuel tank content is converted into a CAN signal by the instrument cluster and transmitted on the CAN. This is received by Fuel Fired Booster Heater (FFBH) control module (if fitted) to suspend operation of the FFBH on diesel variants when the fuel tank content reaches 14 liters or less.
The following shows the fuel tank fuel quantity and the respective pointer positions.
Fuel Tank Quantity (Liters) against Needle Pointer Position
4.91 liters - needle will show : Empty
12.5 liters - needle will show: Low fuel (low fuel lamp illuminated-Petrol engine)
14 liters -needle will show : Low fuel (low fuel lamp illuminated-Diesel engine)
25.6 liters - needle will show: Quarter full
45.8 liters - needle will show : Half full
67 liters - needle will show : Thee quarter full
81.05 liters - needle will show : Full
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #206432 Sat Jan 17 2009 3:40am
dadanek
Czech Republic 2007 Range Rover Sport Supercharged Java Black
Why petrol engine start illuminate at 12.5 and diesel at 14 litres? Shouldnt it be contrary? Laughing RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #206433 Sat Jan 17 2009 3:43am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
How big actually is the tank - pretty sure that (according to the local fuel pumps) I have put more than 81.05 litres in from very close to empty??
Post #206436 Sat Jan 17 2009 6:37am
