Home > General > Snow Chains !? |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Are they not?
Fri Nov 14 2008 8:21pm |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 |
Killerbob you should check out this it goes on 20" wheels. They should cost around EUR 120
Sat Nov 15 2008 7:05am |
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 |
hmmmmm
Sat Nov 15 2008 9:20am |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 |
Yes, that's the same reason why is better to go with winter tires around here, even if the RRS could handle snow on summer tires(even if the crash is not your fault you'll get at least part of the blame.) I went for the 19", yes they are expensive here, but I like to have that bit of shoulder more for winter, still looking for chains, even if I'll probably never use them. '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Sat Nov 15 2008 12:47pm |
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 |
Not in the snow.... wider the better Speed Limits! not where I live! Back in a D3 Did have: RRS TDV8 2008.5MY Did have: Q7 3.0TDi S-Line/Tech/Comms pack Did Have: Disco3 HSE |
Sat Nov 15 2008 1:14pm |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 |
In my experience a narrow tyre works better in most snow conditions as it allows the tyre to cut down through the snow and get some grip inside or underneath the snow. It also creates a "tram line" effect that allows the vehicle to keep its line. A wider tyre can mean the car almost "floats" on top of the snow and doesn't get any traction or directional stability. I guess in really deep snow - wider tyres may mean the vehicle wouldn't "belly out" on the snow. The guys from countries that get lots more snow than we have in the UK will have better wisedom on this. RRS TDv8 HSE Rimini Disco 4 TDv6 HSE Ipanema Defender 90, 200tdi CSW |
Sat Nov 15 2008 3:03pm |
A couple of inches fine, that allows you with the weight of the vehicle to get down to the roadsurface, whether that be tarmac or gravel etc and keep traction. However, if your talking proper snow, wide tyres with low pressures are a must. Just look at the guys in places like Canada, Iceland, Norway etc, they run on a min of 38" upto 44" Speed Limits! not where I live!
Sat Nov 15 2008 5:08pm |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
How far north are you thinking of going Josh. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass. __________________ Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!! |
Sat Nov 15 2008 5:25pm |
TheLynxEffect Member Since: 07 Nov 2007 Location: Midlands Posts: 38 |
I took my RRS to Val D'Isere last year and off to Switzerland this year and never had a reason to use Snow chains. Even before the roads had been cleared, the Pirellis did the job adequately as long as you drive sensibly and use the Snow Traction setting.
Sun Nov 16 2008 12:06pm |
What about that www.easy-winter.com for EUR 56 Are those acceptable? 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
Wed Nov 19 2008 12:28am |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
One of the greatest programmes ever made Runner up - 2009 Best Avatar Award Joint runner up - 2009 Outstanding Contribution Award WINNER - 2008 ‘Best Thread’ Award – Beautiful Women Of The World Runner Up - 2008 Comedian Of The Year Award Runner Up - 2008’s Funniest Incident 06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods - GONE - ( |
Wed Nov 19 2008 7:29am |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Oh somewhere around northern edge of Yorkshire Dales depending on what's available in 2 years time TDV6 - gone TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
Fri Nov 21 2008 12:17pm |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
it will start snowing here today
Fri Nov 21 2008 12:30pm |
