| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Australia & New Zealand > Wiper Blades |
| Zilch Joined: 20 Mar 2006 Location: way way down South.. Posts: 953
back on topic, here you go.. apparently some of the D3 guys found some quieter OEM blades
| ViewWise Joined: 13 Mar 2008 Location: London Posts: 297
only my rear wiper blade squeaks |
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 20143
Same here i have a rear problem as well |
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1812
MDP posted this way back...
cheers bobby, can they be used front and rear |
Good luck! |
| peterl Joined: 02 Jul 2007 Location: Melbourne Posts: 12
Had all my wiper blades changed at my last service at Melbourne City Landrover. Took all the tech posts off this site with the recommendations from LR UK re changing to alt. blades. No probs. Wiper blades Ok. No juddering. So far good. |
| 2nd Rower Joined: 12 Nov 2007 Location: VIC Posts: 207
I have the $10 Supercheap Auto replacements that the Pikeys found.. Only problem is I can't get the originals off. Does anyone have instructions as to how to remove the complete wiper at the end of the arm (not just the rubber blade) 2008 WHITE TDV6 |
If you want to remove the whole pivot arm, just remove the nut cover and unscrew the nut.
| Supertrotter Joined: 10 Mar 2006 Location: Freezing my spuds off in Blighty (For a few weeks anyway!) Posts: 7293
Had our front blades changed by our stealer in Limassol and can confirm that, although we have had no rain for moonths now that using windscreen washers/wipers seems that juddering has disappeared. |
