Home > General > Goodyear mtr/s
Lex
Australia
Goodyear mtr/s
Just put a set of mtr/s and 19inch wheels on my car for offrad work. I must say that the level of road noise does nothing for the driving experience. Can't wait for this evening when I can get the 20's back on. I don't know how many of you guys use mtr/s as your every day tyre but I would rather drive around in a Lada Niva if that were my only option.
Post #167972 Thu May 01 2008 1:34am
It's not that bad! Laughing 2005 Zambezi TDV6 - Gone but not forgotten
Post #167974 Thu May 01 2008 7:13am
It's all subjective - they are noisier on road, but not so bad it'd make you want to drive a Niva! Laughing
Post #167980 Thu May 01 2008 8:44am
Pelyma
Use the noise canceling button on the steering wheel. Porsche Cayenne S Diesel 66 Plate
Post #167999 Thu May 01 2008 9:32am
dukemasterpro
Australia
Interested to see Lex, you are a fellow Aussie based RRS owner. Have been quoted for the same tyre here and would be keen to know how you think the car performs off-road with them - do they rub at all? what did you do with the spare?
How about on road though are there speed rating or load issues to think of as well.
I'll be on the lookout though later this year for a spare set of rims with these tyres for some weekend and longer tag along trips.
Post #168024 Thu May 01 2008 11:11am
Lex
Australia
I'm actually running these tyres on a vogue tdv8. But the 19 inch RRS wheels fit over the Brembo brakes--just.I got the wheels cheaply as the tyre dealer had some second hand stock. The tyres are very expensive at a rrp of around $600.0 each for 255/55 19.But I've tried a couple of Cooper patterns in 20 inch and the tyres are much too big. So if you want a good heavy duty tyre in 19 inch wheel size; the Goodyear mtr is the only one I can find. I havn't had a chance to get off the bitumen yet but I'm sure that they will perform very well.They are exactly the same size as a 250/50 20 so fit and speedo are not compromised;also very heavily constructed so stones/rocks should not be an issue offroad. Just too noisy/rough for long term on road use.
Regards
Lex
Post #168172 Fri May 02 2008 1:36am
dukemasterpro
Australia
Does your spare MT/R fit underneath?
Post #168449 Sun May 04 2008 10:03am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
DMP i see from the D3 site you are off on an adventure with the RRS, have you worked out the modification costs. i had a good offer for tracks and rails from Roof Rack City on the Pacific Highway, and might be worth dropping a note to Rangie about the best dual battery system and fridge for the Sport, he has moved to a Pajero just recently, but had a highly adapted Sport for a few years geared for the off-road, he can normally be found here http://forum.australia4wd.com/ under the same name.
Jim Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #168463 Sun May 04 2008 12:55pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
No Problem Thumbs Up Sons of dogs come hither and get flesh
Clan Cameron
Post #168525 Sun May 04 2008 9:35pm
dukemasterpro
Australia
Jim
Yes, it's quite expensive Rolling Eyes , if you want the full monty of gear. Had a good response on the D3 forum, so hoping to squeeze the cost down as much as possible. Whilst it's a big trip and holiday we want it does not make sense to modify any more than is needed or buy items that would get used on 3-4 long weekend and 8-10 day trips each year.
Considering buying some items like the dual battery system and hiring others eg a camper trailer to keep costs down. Getting the right tyres will probably be the biggest outlay. Shocked
Post #168568 Mon May 05 2008 12:01pm
dukemasterpro
Australia
Further thought, with the MTR's - how is the ground clearance? Does the vehicle height get increased, this would be useful off road.
Save getting into "super extended mode" on those conservation mounds.... Whistle
Post #168573 Mon May 05 2008 12:32pm
Lex
Australia
I'm pretty sure that the diameter of mtr 255/55 19 is just about the same as 255/50 20 as fitted standard give or take a millimetre.
Post #168669 Tue May 06 2008 9:51am
Alicatt
Dunno about over in Australia but here the car comes standard with 275/45/20" = dia 756mm. The MT/R is 255/55/19" = dia 763mm so 7mm or 0.93% diffrence.
The 255/50/20" = dia 763mm so no diffrence in diameter with the MT/R.
Calc your own here http://www.tyresave.co.uk/tyresize.html Sons of dogs come hither and get flesh
Clan Cameron
Post #168747 Tue May 06 2008 4:52pm
dukemasterpro
Australia
Anyone know if the 19" inch MT/R rim and tyre combo can be changed in the bush using a tyre repair kit, levers etc?
Was thinking of throwing a spare carcass on the roof as a 6th tyre in case of punctures since it is very unlikely we would be travelling with anyone else having the same spare.
From what I have been told this may be a tad impossible without a full workshop nearby
Post #169233 Sun May 11 2008 6:50am
