| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > General > Goodyear mtr/s |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14621
It's not that bad! |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: I'm having the best day of my life, and I owe it all to not going to Church! Posts: 19749
It's all subjective - they are noisier on road, but not so bad it'd make you want to drive a Niva! |
| Pelyma Joined: 29 Sep 2005 Location: Clymping, Sussex Posts: 1002
Use the noise canceling button on the steering wheel. DS3 TDV6 HSE
| dukemasterpro Joined: 06 Jan 2008 Location: Sydney Posts: 26
Interested to see Lex, you are a fellow Aussie based RRS owner. Have been quoted for the same tyre here and would be keen to know how you think the car performs off-road with them - do they rub at all? what did you do with the spare?
| Lex Joined: 17 Mar 2008 Location: Toowoomba Posts: 8
I'm actually running these tyres on a vogue tdv8. But the 19 inch RRS wheels fit over the Brembo brakes--just.I got the wheels cheaply as the tyre dealer had some second hand stock. The tyres are very expensive at a rrp of around $600.0 each for 255/55 19.But I've tried a couple of Cooper patterns in 20 inch and the tyres are much too big. So if you want a good heavy duty tyre in 19 inch wheel size; the Goodyear mtr is the only one I can find. I havn't had a chance to get off the bitumen yet but I'm sure that they will perform very well.They are exactly the same size as a 250/50 20 so fit and speedo are not compromised;also very heavily constructed so stones/rocks should not be an issue offroad. Just too noisy/rough for long term on road use.
Does your spare MT/R fit underneath? |
| Zilch Joined: 20 Mar 2006 Location: way way down South.. Posts: 936
DMP i see from the D3 site you are off on an adventure with the RRS, have you worked out the modification costs. i had a good offer for tracks and rails from Roof Rack City on the Pacific Highway, and might be worth dropping a note to Rangie about the best dual battery system and fridge for the Sport, he has moved to a Pajero just recently, but had a highly adapted Sport for a few years geared for the off-road, he can normally be found here http://forum.australia4wd.com/ under the same name.
| Alicatt Joined: 11 Jun 2007 Location: Eating in Eksel or Working in Wick Posts: 708
Further thought, with the MTR's - how is the ground clearance? Does the vehicle height get increased, this would be useful off road.
I'm pretty sure that the diameter of mtr 255/55 19 is just about the same as 255/50 20 as fitted standard give or take a millimetre. |
Dunno about over in Australia but here the car comes standard with 275/45/20" = dia 756mm. The MT/R is 255/55/19" = dia 763mm so 7mm or 0.93% diffrence.
Anyone know if the 19" inch MT/R rim and tyre combo can be changed in the bush using a tyre repair kit, levers etc?
