| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Maintenance & Modifications > Retro-fit Adaptive Xenon's |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 15233
As far as I'm aware you can swap halogen lights for the Xenons but NOT the adaptive Xenons. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
BTW - good price. Hope they came with the bulbs as these cost £130 each. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 8082
I wonder how you would connect the "adaptive" bit up to the steering system to make them point with the wheels? A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
| dai748 Joined: 08 Feb 2008 Location: Wales Posts: 8
I'm going to try them out tonight so I will let you know how it went |
Just fitted the headlamps |
| Steve in germany Joined: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 915
At very low speed ie turning into a junction or into your drive, you will clearly see a shift in the beam. Speed Limits! not where I live!
They aren't in the main lamp headlamp cluster which makes you wonder why they call them adaptive headlamps! There is a second side light lamp in the side light pod and when you turn the steering wheel or indicate one way the lamp on that side comes on in a sort of spotlight mode rather than a floodlight mode! This second lamp has it's lamp pointing straight ahead so there must be a very complex reflector at the back to focus it to one side. I'm not complaining mind - they are excellent of twisty country roads at night or in carparks.
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 2006
I'm sure there will be problems with these. The D3 chaps have talked about this and I would guess the system is the same. You will not get the correct coverage. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
| All times are GMT |
Staying - Epsom Green Defender 90 for playing off road
