Home > General > Sand Duning In South Africa |
sportman Member Since: 25 Jul 2005 Location: UAE Posts: 550 |
qho you did not use sand setting in the terrian responce and why low gearing yoo need more momentoum that hight torque
Mon Jan 21 2008 11:19am |
Seanvodashop Member Since: 20 Oct 2007 Location: Kimberley Posts: 22 |
Hi Sportman, these dune are coastal sanddunes that have very high traffic and as a result of the traffic the dunes start forming corrugation humps and therefore the ice setting, which stiffens the suspention, causes less energy loss through the car bouncing and works like a charm. The reason I use low range is because when my TDV8 is in high it gears up too far (4th/5th) based on the speed and revs and then refuses to gear down when I need higher revs again, resulting in high gear low speed. Another reason is that when you drive in Low it puts less stress on the motor, but still gives enough speed and momentum in the soft sand. If you have advice to give, I'll take it gladly seeing as you should be an expert considering your location. |
Mon Jan 21 2008 2:53pm |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
Seanvodashop, good to see a RRS offroad in SA. I'd recommend you take off the front spoilers next time - just a couple of screws, or they WILL get damaged.......I think Compomotive may have a distributer in SA - their 18" PD1880 Rally rim fits the TDV8 or Supercharged and 18" tyres are easier to find than 19" Goodyear MTRs (the only choice in this size).
Mon Jan 21 2008 3:10pm |
Thanks Leo, are you sure that the 18's fit the Brembo calipers? No I havn't tried outa RSA diesel yet, but I know that we don't have the best D arround. Thanks again. |
Mon Jan 21 2008 7:13pm |
Yes, 100% sure that the Compomotive 18" in the link below will fit without modifying the Brembo calipers - unlike most other 18"ers. Can you get 19" Goodyear MTRs in SA? I know you can get 18" Bridgestones. Anyway, check out page 2 of the following link:
Mon Jan 21 2008 11:17pm |
Shot Leo, I'm gonna give the 18's a bash. Let u know about the MTR's |
Tue Jan 22 2008 5:50am |
