![]() | Home > General > Dropped Tailgate |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 242 ![]() ![]() ![]() |
Boot spoliler off, disconnect the boot lid struts, slacken the 4 nuts for the 2 hinges and give it a shove and retighten. Best to have one person holding it in it's new position and one person to re-tighten the nuts otherwise it's a bit tricky!
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 149 ![]() ![]() |
Thanks - so just need to decide if I'm prepared to take my RRS apart or whether I'm more comfortable asking my pal at the bodyshop for an hour's labour. 2021 L494 D300MHEV Autobiography
If you are doing it yourself, when unbolting the spoiler hold the studs with a torx socket whilst you remove the 10mm nut as the stud is also used to adjust the spoiler height so you don't want to disturb the length of them.
