Home > My Range Rover Sport > What is this part number
jig
2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Hi
Was going to change the coolant flange on my l320 and this pipe from the airintake box snapped off it is very brittle and the part number is unlegible.
Please can someone tell me if I can just replace the pipe and where I can possible get it or if it is stealers only?
Thanks in advance
Post #650155 Sat Oct 11 2025 11:52am
jig
Also is it possible to repair temporarily??
Post #650156 Sat Oct 11 2025 11:52am
I don’t think you will get many replies in this subsection. Use ones near the top.
Look numbers up here.
https://parts.jaguarlandroverclassic.com/p...and-rover/
Then search on eBay or
Www.Advancedfactors.co.uk
Post #650158 Sat Oct 11 2025 12:49pm
NoExpert
That’s a whole assembly going to the secondary turbo. If you find a used one from a newer 3.0 it’s a formed rubber hose with a clamp and one way valve. You can easily remove and put on just the broken bit. Temporarily you can just use vacuum hose and appropriate sized clips.
This is an updated version I put in my 2011:
 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #650159 Sat Oct 11 2025 1:53pm
jig
Thanks Andy very useful as always. Sorry posted in a panic!!
Post #650160 Sat Oct 11 2025 1:55pm
jig
Thabks you are a star now I just need to find the part number of a newer one
Post #650161 Sat Oct 11 2025 1:55pm
NoExpert
Found it, LR084276 https://www.famousfour.co.uk/new_parts/ff_part?part=31996 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #650162 Sat Oct 11 2025 2:16pm
jig
amazing thank you you are an expert!!
Post #650163 Sat Oct 11 2025 2:23pm
jig
thanks do you know if the top part just pulls off?
Post #650164 Sat Oct 11 2025 2:24pm
NoExpert
On the original hard pipe you need to delicately cut the pipe and then you can remove the end.
On the new part the rubber hose is held to the metal pipe with a hose clip. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #650166 Sat Oct 11 2025 7:02pm
