![]() | Home > My Range Rover Sport > What is this part number |
jig Member Since: 14 Jan 2018 Location: London Posts: 49 ![]() ![]() |
Also is it possible to repair temporarily?? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
I don’t think you will get many replies in this subsection. Use ones near the top.
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 517 ![]() ![]() ![]() |
That’s a whole assembly going to the secondary turbo. If you find a used one from a newer 3.0 it’s a formed rubber hose with a clamp and one way valve. You can easily remove and put on just the broken bit. Temporarily you can just use vacuum hose and appropriate sized clips.
Thanks Andy very useful as always. Sorry posted in a panic!! |
Thabks you are a star now I just need to find the part number of a newer one |
Found it, LR084276 https://www.famousfour.co.uk/new_parts/ff_part?part=31996 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
amazing thank you you are an expert!! |
thanks do you know if the top part just pulls off? |
On the original hard pipe you need to delicately cut the pipe and then you can remove the end.
