Home > Maintenance & Modifications > L494 battery charging
Michael997
I have just bought a 2014 L494 diesel, I usually kept my previous L320 battery topped up with my C-tek charger but I have only just discovered this model has two batteries, a main battery and what I believe is a small start/stop battery.
My question is, can I connect a C-tek traffic light lead to either or both batteries and keep them topped up?
The handbook seems to suggest the batteries should not be charged while connected to the car as a risk of damaging the electronics, can this be true? Michael
2014 RRS diesel HSE
Post #649491 Tue Aug 19 2025 8:50pm
Golan
United Kingdom 2013 Range Rover Sport SDV6 HSE Bonatti Grey
I’m no expert but I have a 2016 diesel and I like you I’ve always kept my cars charged with a C-Tek.
I hard wired mine and haven’t had any issues.
Plus I’m not a fan of Stop-Start so I found a thread on here on how to disable it so I don’t have to remember to press the button every time I start it.
Hope this helps.
Post #649492 Tue Aug 19 2025 9:10pm
Michael997
Thank you for that, like you I am not a fan of start/stop, how did you disable it?
When you hardwired the main battery did you use the C-tek traffic light lead?
Michael Michael
2014 RRS diesel HSE
Post #649493 Tue Aug 19 2025 9:24pm
Golan
I can’t remember the model of the charger but it was one of the maintenance type chargers, if it helps I can get the model number in the morning.
As for the Stop-Start there are types one has a battery and the other has a capacitor, here’s the link I used to find out how to disable it.
https://www.rangerovers.net/threads/auto-s...le.341127/
Happy reading.
Again I hope this helps.
Post #649495 Tue Aug 19 2025 10:04pm
Notyalc
Don’t connect the -ve lead to the battery attach it to an earth point or chassis. This is to allow the BCM to work as it should.
Post #649509 Wed Aug 20 2025 8:01pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
I have a 2015 year RRS and use my CTEC charger on the terminals under the bonnet. It charges up both batteries from there.
Post #649512 Wed Aug 20 2025 11:28pm
Michael997
Thank you all for your reply’s
I will give it a try. Michael
2014 RRS diesel HSE
Post #649516 Thu Aug 21 2025 3:59pm
