![]() | Home > Maintenance & Modifications > Front wheel bearings |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
As you've found out, buy cheap buy twice
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 217 ![]() ![]() ![]() |
Hi Mikey hope your well with your vast knowledge and experience would you say the Timken is a good option to go for ? I checked the new febi one I fitted no play at all when I checked with it jacked up no noise going around corners just the same as one I replaced Not as bad but noise at 60ish.When I put it on originally it was fine lol.Have a good one up their in Bonny Scotland |
Timken are OE, and the only bearings we fit to D3/4/RRS ๐ |
Hi Mikey thanks for your wise words appreciated |
