Home > Maintenance & Modifications > Front wheel bearings
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi replaced a front wheel bearing about 3 weeks ago febi brand itโ€™s now already making a noise !!! WTF torqued correctly to latest LR bulletin.Have ordered Timkin bearing to replace and send the febi one back lesson learned buy cheap buy twice Big Cry
Post #649488 Tue Aug 19 2025 7:27pm
Disco_Mikey
As you've found out, buy cheap buy twice
We had a car in today, customer replaced a rear shock and top mount to cure a suspension knock, and bought cheap unbranded parts. The knock was worse after fitting the new parts Laughing
A new OE shock and top mount, and it was silent Thumbs Up
Post #649490 Tue Aug 19 2025 8:01pm
Iomegas
Hi Mikey hope your well with your vast knowledge and experience would you say the Timken is a good option to go for ? I checked the new febi one I fitted no play at all when I checked with it jacked up no noise going around corners just the same as one I replaced Not as bad but noise at 60ish.When I put it on originally it was fine lol.Have a good one up their in Bonny Scotland Thumbs Up
Post #649501 Wed Aug 20 2025 12:02pm
Disco_Mikey
Timken are OE, and the only bearings we fit to D3/4/RRS ๐Ÿ‘
Post #649507 Wed Aug 20 2025 5:53pm
Iomegas
Hi Mikey thanks for your wise words appreciated Thumbs Up r
Post #649508 Wed Aug 20 2025 7:03pm
