Home > General (L494) > 21 inch tyre recommendations. On and off road.
shatnersbassoon
Hi All,
My new to me RRS had 2 new front tyres fitted by the place I bought it from when they MOTd it. It had 4 pirelli scorpions on it when I viewed, but now has scorpions on the back and Iota ST68s on the front.
The ST68s are the correct size, but look like some kind of stretched tyre, are rubbish in the dry, scary in the wet, and absolutely useless offroad. I took it down some slightly damp rutted tracks today, and there's no way those tyres would ever climb out of a rut! I thought I was going to get stuck!
Anyway. My question is; what tyres would everyone recommend? I'm 99% on road, but I want the capability to do the odd bit of green laning. Should I just replace the brand new ST68s with some more scorpions, or is there a better tyre if I replace all 4 that fits my needs?
These are the 21 inch wheels by the way.
Post #648972 Sun Jul 20 2025 9:06pm
DWA
Hi there, personally I have never gone past Pirelli Scorpion Zero All Season, used them for years on disco's and rrs, always been happy with them on road and will take you anywhere you want to go off road.
Post #648996 Tue Jul 22 2025 12:37am
Yes, bin the Iota and fit Pirelli to match the other axle. The OEM Pirelli fit will do pretty much everything you might want to do short of mud plugging - certainly green lanes with reasonable surface will be no problem. The car was designed around that type of tyre after all.
If you want a bit more off road grip then something like the Grabber AT3 does well and is winter rated. But won't be anywhere near as good on the road as the more road oriented Pirelli if pushed e.g. heavy braking, high speed cornering. All Terrains are a compromise that, for 99% road use, you might not wish to make. 2012 SDV6 - it's missing a couple of cylinders
Post #649002 Tue Jul 22 2025 10:40am
shatnersbassoon
Thanks for the replies.
I guess it was a choice between the Grabbers and the Scorpions anyway, as there aren't many options out there for these wheel sizes.
I'm not planning on doing anything in really deep mud, would be nice to explore some of the more challanging green lanes round here without worrying too much about getting stuck.
Certainly just replacing the fronts is the cheaper option in the short term.
Maybe I'll try and pick up some cheap tatty 20s at some point and put some more off-roady tyres to play with in the winter.
Thanks
Matt
Post #649004 Tue Jul 22 2025 6:23pm
