Home > Faults & Fixes > Gearbox neutral.
4on4off
Gearbox neutral.
Good morning, I have discovered this and wanted a bit of feedback from the more experienced on here. As you can see the bracket has been brocken but the cable which I believe should be attached to a lever on the gearbox, has no tension. I have pulled it 2-3" but no further. Any thoughts would be appreciated. Thanks.
Post #648691 Fri Jul 04 2025 6:06am
Can't actually see anything. Laughing
Post #648692 Fri Jul 04 2025 6:24am
4on4off
Gearbox neutral.
A bit early. This time hopefully you can see the photos. 2016 3.0 SDV6.Cheers, James.
Post #648693 Fri Jul 04 2025 6:34am
nope, still no photo --
Post #648694 Fri Jul 04 2025 8:16am
4on4off
Apologies all.
Post #648695 Fri Jul 04 2025 9:12am
