Home > Technical > Weird Restricted Performance only after 4 hours drive
evans21
Greece 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I know this is a common issue for TDV6 engines but mine only occurs in long runs after around 3-4 hours continuous driving.
The fault codes:
P22CF-71 - Turbocharger turbine inlet valve control circuit - Open
P22D2-77
The car drives fine full-throttle smooth engine but in long trips (which I use the car the most) it gives me RP and the above fault codes.
So far i have done the following with no success:
CSOV Solenoid replacement.
CSOV actuator clean check and lubrication moving freely.
Checked vacuum hoses at the front of the engine everything seems fine.
EGRs seem to work just fine and held open steadily.
I have no idea where to go next no mechanic is able to advise what is wrong with the car. Could this error be related with TSOV? I guess all the vacuum solenoids work within the same system so I guess fault in one of them could trigger these fault codes?
Post #648530 Tue Jun 24 2025 10:21am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Looks like the turbine intake solenoid sticking, see the DTC list below: -
https://www.rrsport.co.uk/gallery/albums/u...C%20VE.pdf
Post #648531 Tue Jun 24 2025 11:24am
Heremyjill
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Good morning, Here is a link to my experience with this codes
https://www.rrsport.co.uk/forum/topic62345.html "Every Day is a School Day"
Now 2014MY RRS SDV6 AB
Now 2018MY Ford Fiesta ST Line 140bhp
Gone 2006MY BMW X5 3.0d Le Mans
Gone 2001MY BMW 530d Estate
Post #648532 Tue Jun 24 2025 11:40am
evans21
thanks for the info. Which one is the turbine intake solenoid? Is it for the TSOV at the back of the turbo or the CSOV the bypass valve behind the intercooler? Isn't it weird that this happens only after long drive which implies that something gets heat-soaked and doesnt operate as normal
Post #648533 Tue Jun 24 2025 11:51am
2 RRS
It's to control, the TSOV on the rear of the secondary turbo. I guess the solenoid coil could be breaking down under sustained heat soak.
Post #648534 Tue Jun 24 2025 12:23pm
evans21
Thanks for the guidance i will check the TSOV and update. With my logic it could be that actual TSOV got some carbon build up and upon high temps its expanding and getting stuck, but hopefully is just a solenoid. Has anyone experienced removing and cleaning the TSOV resolves the problem?
Post #648536 Tue Jun 24 2025 12:41pm
2 RRS
You could try exercising it with a vacuum pump to see if its holding vacuum and closing smoothly as they do clunk when closing. I'd still go for the solenoid being the problem!
Post #648537 Tue Jun 24 2025 12:45pm
evans21
I agreesounds like the solenoid is more reasonable. Also there is another solenoid on the from the rh side of the vehicle (secondary turbo side) where the vacuum lines go before the TSOV. Could this be the one or the one in the front of the engine?
Post #648538 Tue Jun 24 2025 1:50pm
evans21
Hi, after some research i found that the above is the solenoid which controls the TSOV but it seems that i cannot find the new part. It is sitting in the red circle in the diagram to give an idea about the location. I will do some more research and also try to test TSOV itself if easily accessible from underneath
Post #648540 Wed Jun 25 2025 6:28am
2 RRS
It's callout 9K378 on the diagram,
TO VINFA999999
LR029417 - Solenoid - Turbo Control
LR076235 - Solenoid - Turbo Control
£202.94
https://parts.jaguarlandroverclassic.com/p...and-rover/
Post #648543 Wed Jun 25 2025 8:59am
