Home > General (L494) > ABS Module Wiring Diagrams
Nicard
Hi, can anyone share the wiring and pin connector diagrams for the ABS unit for RRS 2016
Post #648482 Sun Jun 22 2025 7:46pm
Nicard
Managed to get a copy of the wiring diagram but still looking for the pin connector diagram.
I am getting low voltage (1.1V) at front left wheel sensor connector from ABS Control module. Checked all other voltage at the connectors to the remaining sensors and getting a consistent higher (12V) voltage reading. Checked and cleaned the ground wires and visually checked cables where possible hence the reason for looking for the pin connector diagram so I can check output directly from the module to rule out any cable issue.
Post #648502 Mon Jun 23 2025 2:50pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
The pin positions are shown on the wiring diagram, front left wheel sensor shows: -
Sensor Plug ref C1CA03-2 Power from ABS connector C1CA01A-19, VT-WH, 0.5, 605
Sensor Plug ref C1CA03-1 Return to ABS connector C1CA01A-8, YE, 0.5, 600.
If you need the actual plug picture then you need the iEWD diagrams which are only online via Topix, if you subscribe to that, clicking on the connector ref (as above) will open a window and show the plug, location, pin positions and spare plug/pin ordering info. I've found the pdf diagram is sufficient for most problems, but bit the bullet on a couple of occasions and paid up!
Post #648503 Mon Jun 23 2025 3:07pm
