2 RRS
The pin positions are shown on the wiring diagram, front left wheel sensor shows: -
Sensor Plug ref C1CA03-2 Power from ABS connector C1CA01A-19, VT-WH, 0.5, 605
Sensor Plug ref C1CA03-1 Return to ABS connector C1CA01A-8, YE, 0.5, 600.
If you need the actual plug picture then you need the iEWD diagrams which are only online via Topix, if you subscribe to that, clicking on the connector ref (as above) will open a window and show the plug, location, pin positions and spare plug/pin ordering info. I've found the pdf diagram is sufficient for most problems, but bit the bullet on a couple of occasions and paid up!
Mon Jun 23 2025 3:07pm |
