Home > Technical > Air con fault
BLODERS
United Kingdom 2013 Range Rover Sport 4.4 V8 Autobiography Firenze Red
Air con fault
Hello
My L494 has a small air con leak
I had it teased and dye added. I cannot see the dye. Have looked on front of condenser
Are there any areas prone to failure on these to make my search any easier?
Thank you
Post #648357 Fri Jun 13 2025 6:29pm
Disco_Mikey
Usually the condenser at the front, or the rear AC pipes at the rear, if fitted
Post #648360 Fri Jun 13 2025 7:05pm
Grimble
I also have a very small leak, however an annual regas is a huge amount cheaper than condenser replacement. Not likely to keep the car long enough to make permanent repair financially sensible. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #648362 Sat Jun 14 2025 1:47am
