![]() | Home > Technical > Air con fault |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
Usually the condenser at the front, or the rear AC pipes at the rear, if fitted |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 274 ![]() ![]() |
I also have a very small leak, however an annual regas is a huge amount cheaper than condenser replacement. Not likely to keep the car long enough to make permanent repair financially sensible. RRS HSE Dynamic SDV6 2014
