![]() | Home > General (L494) > SDV6 Whine - Help on where to check and what to look at. |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 311 ![]() |
Could be a wheel hub? Had any work done on brakes or anything lately?
streethawk999 Member Since: 10 Jun 2025 Location: Winsford, Cheshire Posts: 2 ![]() ![]() ![]() |
Thanks, had it in the garage as I thought it sounded like a wheel bearing but nothing was found.
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 217 ![]() ![]() ![]() |
Hi I had a similar issue over the last few months thought it was wheel bearing on drivers side but there was no play at all and no noise going around corners at low speed.The noise was only present over 55 mph I replaced the wheel bearing and it’s gone when I checked the bearing that came off you could feel a rough spot in its rotation. |
